jclarkr6
I bought a Watson W-889 Tele Gainer BNC Portable Antenna brand new back in June and yesterday the black, flat "tip" of the antenna fell off. Besides being disappointed (I thought this was supposed to be a good antenna), I am concerned that this may affect the antenna's performance. Overall, the antenna still seems to be getting ok reception, I'm still listening carefully to see if I can tell a difference. Does anyone know if the black, flat tip of the W-889 affects the reception? Or is the tip only there to make it easier to grab the antenna to extend/retract it?
Also, should I bother to repair it? If so, how should it be repaired? I wondered if I could superglue the tip back on, as it looks like that might work. Would superglueing the tip back on have a negative effect on the performance of the antenna? I would appreciate anyone's input on this situation. Thank you.
