n9lea
- Joined
- Feb 12, 2005
- Messages
- 7
I've had a Ringo Ranger ARX-2B sitting around in the basement for a number of years. It worked well when I took it down from an old house.
I put it up on the roof the other day, mostly for use as a scanner antenna on VHF, and it barely performs better than a rubber ducky.
There's new feedline to it - it and the various connections appear good and check out just fine with an ohmmeter.
Here's the question: When I measure the resistance across the feedline with the antenna connected, I get 1 ohm, which is basically a short. Is this normal? I wouldn't expect so. If not, is there a particular place on this antenna (like that coil or somewhere) that I should be checking out? I do plan to check that coax stub once I get up on the roof again.
Thanks!
Thanks!
