Looking for the URL or article I used to build the attached scanner antenna. Vertical is 19 inches for the chassis connector to the tip. Plans called for UHF connector and 10 or 12 Ga wire. I used 14 Ga romex on bnc connector strictly for indoor use. Recommended for use on 150/450/800 bands. Antenna analyzer does indicate appropriate characteristic near 150 and 450, but analyzer does not cover 800. Seems to work well for what I listen to in the Grapevine, TX area.
Originally I thought I found the article in RR links to Wiki a couple of years back, but the only thing I found was the off-set vertical dipole today.
Any help would be appreciated.
