How far should my CB antenna be from scanner antenna on my car?
BillH1
Golden Valley AZ
I have a scanner antenna and cb antenna on my van about 30 inches apart. The cb is stock, so 30 inches should be more than enough right? I don't want to take any chances and damage my scanner.
jonwienke
More Info Coming Soon!
VA
That depends on your scanner antenna and a bunch of other variables we can't analyze.
Get a RF wattmeter and a dummy load, and connect to the scanner antenna lead. Key up your CB and see what kind of a reading you get.
FWIW, my 436 does fine getting hit with 500 milliwatts of RF from other radios. If your reading is less than that, you're probably fine. YMMV
BruceMN
Duluth, Minnesota
There will probably be issues on your scanner if you key up the CB. My recommendation is to turn off the scanner if you want to transmit on the CB. I use to do this with my scanner with a 2 meter ham radio without any issues to the scanner. You would probably blow out the front end on the scanner if you did not turn it off before you transmitted with the CB.
Bruce N0JX
Bruce N0JX
This will do absolutely nothing to protect the scanner.
The power switch for the scanner does not disconnect the antenna from the front end stages of the radio. It's the delicate electronics in the front end of the receiver that would get damaged from too much RF energy getting into it. Shutting off the power doesn't do anything to protect that.
If your scanner has not been damaged by the 2 meter radio, its because there is sufficient antenna separation, coaxial losses and probably a stout enough front end.
@OP:
The CB puts out 4 watts tops. Probably more like 3.5 watts. Add in the coaxial cable losses and you are probably lucky to be getting 3 watts RF out at the antenna, probably less. The coupling between the two antennas with 30 inches of spacing is probably getting very little RF into the scanner.
Jon's suggestion about the RF watt meter and a dummy load is a good one, it'll show you how much RF is getting to the antenna jack on your scanner. Truth is, unless you have a meter that is really good at reading very low power levels (as in milliwatts), you probably won't even see anything.
The other variable is how well the scanner is protected by the diodes they usually put on the antenna connection to protect the receiver.
