With limited space, I have set up 3 scanner antennas close together. They are about 12 to 24 inches apart. Each is a single element 16 inches tall with a metal ground plane about 12 inches square.
Will their proximity interfere with reception, diminish signal strength, etc.?
I have multiple scanners each with a devoted antenna. I mainly listen to trunked digital systems in the 700 and 800 Mhz range.
Thank you.
Thank you.
