CorwinScansNM
Hello Radio Reference users & members,
I have a quick question that I do not know or understand but that I know many of you will or already do know. I am planning on ordering a really high user rated Commercial Antenna on eBay for my scanner receiving only use & benefits. However, there is an option of choosing a (Maximum power input 75 watts) or a 250 watt version that is also available for this antenna.
I am not sure which of those 2 watts I would need or should choose for receiving the following specified frequency ranges that I plan to receive on my Uniden BCD536HP Digital Scanner. My frequency receiving ranges that I would be monitoring with this antenna are: 118-136 Mhz, 150-174 Mhz 400-470Mhz & lastly, 806-956 Mhz.
Then, my 50 foot LMR-400 Coax Cable from the antenna to a Electroline EDA 2100 Drop Amplifier & finally, from the drop amplifier to my scanner. I maybe & hopefully can eliminate using the Electroline EDA 2100 Drop Amplifier if this antenna works as expected & as well as previous buyers are saying that it does & raving about its performance.
Any advice or suggestions on what wattage out of the 2 available for this antenna I should choose for my specified use? Thanks!
