Hi,
I need a little advice on using an antenna for base station scanner reception.
I will be using my BCd536 Uniden receiver with a roof mounted antenna.
The frequencies I will be monitoring are some vhf 136-174mhz, a lot of Uhf 430-512mhz, and lots of the 800 mhz band for digital trunking.
The antenna I intend to us is a vhf/uhf yagi with amplified booster and 360 degree rotation it's for TV channels but also covers all the scanner frequencies I listed, I intend on using RG 6 quad shield cable. 100' Here are my questions:
1- Will the fact that the antenna and cable are 75 ohm impedance and the scanner calls for 50 ohm impedance make a "big deal" I mean not in terms of measured theory but in real life reception.
2-Should I mount it vertically or horizontally.
Thank You
Thank You
