- Joined
- May 15, 2014
- Messages
- 84
I got this older scanner antenna with a bunch of other stuff a while back and was hoping someone could tell me what antenna it is. The three radials and the vertical element are 19 inches long. The two shorter vertical elements are 4.5 inches tall. The connector is for a PL-259. The lengths indicate it should be good for 150 and 450 MHz but the specs (if it can be identified) may tell me more about it.
I don't see any markings on it. They are probably worn off. I thought someone here may recognize it. I am not sure why is shows up sideways!
