https://1drv.ms/u/s!ApJIS-l4xqPtgvl8X-hGsUu8icErsA
The simulations indicate it should perform well from 100MHz to about 1GHz, with significantly more gain than a standard discone. It's basically a discone flipped upside-down, with the cone becoming the active element, and the disc stretched out to form a large ground plane, and then bent down a little bit to bring down lobes of the radiation pattern closer to the horizon.
Chracteristic impedance is nominally 900 ohms, but it's actually 75 ohms because I had to use 12 power feeds instead of 1, to work around some stupid bugs in NEC.
Comments & feedback welcome.
