Antenna for Icom IC-R7000
rt4768
I'm fairly new to scanning and could use some suggestions regarding indoor antenna choices. With any luck, I am planning on aquiring/buying/finding a used Icom IC-R7000 receiver and would like some input as to what kinds of antenna(s) I could use indoors (I do have a good sized attic that was built with trusses available). I would like some suggestions for either one antenna for all of the frequencies the rig is capable of receiving(25MHz - 2000MHz) or two separate antennas, one for (25-900MHz) and one for (900-2000Mhz). Thanks in advance for any and all suggestions, and best wishes for a safe and enjoyable 4th of July!
Rob T.
k9rzz
Milwaukee, WI
I'd say that's a good start. As you listen more and more and find out what services you like best, antennas cut for those frequencies will allow you to hear more. For example, a good antenna at 154mhz is pretty lousy at 42mhz. A good antenna for CB won't hear as well as a good FM broadcast antenna, etc. But go with the discone and take it from there.
Last year I bought a used Icom R-7100 receiver and I LOVE IT!! I can listen to CB, FM broadcast, TV audio, and the local police and fire departments. I've also heard the audio link for KOA radio out of Denver on 25mhz (I'm in Wisconsin), a TON of NOAA weather stations at 162mhz, all the ham bands (6 meters, 2 meters, 220mhz, 440mhz), and recently was listening to the Tennessee State Patrol on 42 mhz. What makes it especially nice, is that you can tune in the AM, FM, wide FM, or SSB modes, not just in FM like many scanners. When I get tired of listening to one thing, I can listen to something entirely different by simply spinning the dial !
Way cool if you ask me.
