TDMA CODES
BillGiff
HAMBURG, AR 71646
My question is: will the new UNIDEN BCD536HP be able to "hear" Ashley Co. S.O. and Crossett Fire Dept. radio traffic?
I do not find these codes listed and am wondwering if this scanner can "decode" their transmissions?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
BillGiff
HAMBURG, AR 71646
Look again there are more than one freq. listed. 155.0025 is TDMA digital 155.370 is analog and digital.
So this scanner will be able to hear them correct?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No. Those frequencies are listed as DMR which unfortunately, is not supported in any scanner.
N8IAA
Fortunately, GA
So it seems there are more than one DMA hih?
Well anywho it seems/sounds like Crossett P D also went digital this week :(
Don't confuse DMR (digital mode) with DMA (dynamic memory architecture that Uniden uses for the 396/996/15 scanners memory).
Larry
BillGiff
HAMBURG, AR 71646
Well we common folk are just going to have to wait a while for a plug n play scanner to "hear" all this new TDMA and ....... other stuff looks like.
Jay911
And definitely don't confuse any of it with the actual topic of this thread, which is TDMA.
Simply put, TDMA is one way of having multiple users on a trunked radio system. The other is FDMA.
Frequency Division Multiple Access = regular trunking; each user is allotted a different frequency.
Time Division Multiple Access = two (or more) users sharing a frequency by using "time slots", so that in every set period of time, each user is allotted a chunk of that time proportionally. So in a 2-slot TDMA system (like P25 Phase 2 TDMA and X2-TDMA), two users share equal halves of all allotted time on a given frequency during their voice calls.
N8IAA
Fortunately, GA
I'm not the one confused, I understand what the two are. But, the frequencies he asked about are listed as DMR in the RR database. He keeps referring to them as TDMA.
Larry
kayn1n32008
ØÆSØ
Sector 001
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9900; en-US) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.1.0.1047 Mobile Safari/534.11+)
TDMA IS the ota mode for DMR. If a agency/business goes to DMR then it is TDMA. If it is some other form of digital it will be FDMA (like NXDN or P25 unless it is P25 phase 2)
