Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > Scanner / Receiver Equipment Reviews
Scanner / Receiver Equipment Reviews - A forum for reviews of scanner and receiver hardware along with related accessories. Please read the forum Sticky before creating a thread.
  #21 (permalink)
Old 02-06-2015, 6:25 PM
I lucked on a brand new old stock, i have to say I'm impressed with the deference. From the looks i think one of those ebl 9v lithium rechargeable batteries would fit, I'm hearing stations i have not heard in along time.
bcd 536hp bct15 grecom psr-600 Icom ic-10 Grundig S350dl radio gre amplifier gre converter monitor mon52 monr33 austin spectra monitor mon58 antenna baofeng uv-5rv2+ Nagoya na-771 Nagoya na-701antenna
  #22 (permalink)
Old 02-06-2015, 10:14 PM
Do you think a mm or so of extra space is available in all dimensions in the battery compartment?
The EBL 9v is about a mm or so larger all the way around.
  #23 (permalink)
Old 02-09-2015, 9:39 PM
Ok,I've measured one of the EBL 9v batteries. It's .968" L to the top of the terminals,1" W and .906" thick.Comparing it to an Energizer Alkaline 9v it's .031" taller and about the same .031" difference in thickness. Basically 1/32 difference in those 2 dimensions between the two.
Will these fit the GRE without issue? I don't want to purchase one until someone can tell me they will fit.
They fit my smoke detectors fine,but not the ceiling fan remote.They fit in the compartment,but the cover's tab will break if you try to close it.
  #24 (permalink)
Old 02-09-2015, 11:39 PM
Ooops..
I made a big mistake in the conversions
L=.906"
W=1"
thickness=.656"
Sorry about that.
  #25 (permalink)
Old 02-10-2015, 12:19 AM
I opened mine up just now......only had change to measure......could shove 2 US Quarters on the bottom side of the battery and the case, and 3-4 on the side that the "cap" goes over. There is a bit of foam and such that can compress a little bit more even inside. These measurements were taken up to the point where the flimsy tin began to span a bit, not that that would affect anything, it's just a hollow tin with a board inside.
Paul
  #26 (permalink)
Old 02-10-2015, 12:32 AM
Well that sounds like there is easily enough room to fit these batteries with their extra .031/1/32" size difference.
Awesome!
Thanks.
  #27 (permalink)
Old 02-20-2015, 11:57 AM
wheels63's Avatar
Any one know where I can buy one of these ?
Tom
Uniden BC125AT,Uniden BC345CRS.All ways looking for more.
  #28 (permalink)
Old 02-20-2015, 12:11 PM
Gre Super Amplifier for Tracking Receivers Increase Range Connects Inline New | eBay
  #29 (permalink)
Old 03-01-2015, 10:29 AM
By the way, the EBL 9v batteries fit just fine.They last quite a while.Not sure how well the charger works though.
