Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > Shortwave Data Decoding
Shortwave Data Decoding - Discussions regarding decoding digital signals on the HF bands, including HFDL, ALE, RTTY, CW, and others.
Old 09-05-2014, 8:32 PM
Wiki Admin Emeritus
Default New HFDL version 49 table
Thanks to the UDXF, I was alerted that there's a new Version 49 table of sites and freqs. It's too long to post here, so there's a text file attached.
Intereisting that it shows site 11 as Annapolis - a site that went dark a couple of years ago - well now it seems like it's back, although there's still some debate about this...
I will update our HFDL article in the wiki in due course (unless someone beats me to it...)
Old 09-07-2014, 12:17 PM
Wiki Admin Emeritus
As I thought - this is based off an old table. Site 11 should be Panama, not Annapolis, again per UDXF
Sorry for the confusion...Mike
Old 04-19-2018, 7:23 PM
Using the "new" table I was able to hear Annapolis Maryland on 10063 kHz. It is definitely back on the air.
Old 04-19-2018, 9:14 PM
Table 49 (old thread resurrected here) was updated to System Table 50 a year ago.
Utility Planet: HFDL System Table 50 in effect
San Francisco and some other HFDL ground stations have been using System Table 50 as of this morning (local time). This replaces Table 49, which had been used for quite a long time.
No PC-HFDL update file yet, but here it is in squitterese:
Ground Station ID 1 SAN FRANCISCO - CALIFORNIA UTC UNLOCKED
Longitude 121 45 34 W Latitude 38 22 48 N
Squitter Version 0
Number of frequencies 8
Frequency 21934000 Hz Master Frame Slot 4
Frequency 17919000 Hz Master Frame Slot 12
Frequency 13276000 Hz Master Frame Slot 8
Frequency 11327000 Hz Master Frame Slot 4
Frequency 10081000 Hz Master Frame Slot 4
Frequency 8927000 Hz Master Frame Slot 12
Frequency 6559000 Hz Master Frame Slot 8
Frequency 5508000 Hz Master Frame Slot 4
Ground Station ID 2 MOLOKAI - HAWAII UTC UNLOCKED
Longitude 157 10 46 W Latitude 21 10 47 N
Squitter Version 0
Number of frequencies 12
Frequency 21937000 Hz Master Frame Slot 0
Frequency 17919000 Hz Master Frame Slot 7
Frequency 13324000 Hz Master Frame Slot 3
Frequency 13312000 Hz Master Frame Slot 3
Frequency 13276000 Hz Master Frame Slot 3
Frequency 11348000 Hz Master Frame Slot 11
Frequency 11312000 Hz Master Frame Slot 11
Frequency 10027000 Hz Master Frame Slot 11
Frequency 8936000 Hz Master Frame Slot 0
Frequency 8912000 Hz Master Frame Slot 0
Frequency 6565000 Hz Master Frame Slot 7
Frequency 5514000 Hz Master Frame Slot 7
Ground Station ID 3 REYKJAVIK - ICELAND UTC UNLOCKED
Longitude 21 50 59 W Latitude 64 4 47 N
Squitter Version 0
Number of frequencies 7
Frequency 17985000 Hz Master Frame Slo t 11
Frequency 15025000 Hz Master Frame Slot 7
Frequency 11184000 Hz Master Frame Slot 3
Frequency 8977000 Hz Master Frame Slot 0
Frequency 6712000 Hz Master Frame Slot 11
Frequency 5720000 Hz Master Frame Slot 7
Frequency 3900000 Hz Master Frame Slot 3
Ground Station ID 4 RIVERHEAD - NEW YORK UTC UNLOCKED
Longitude 72 38 22 W Latitude 40 52 47 N
Squitter Version 0
Frequency 21931000 Hz Master Frame Slot 1
Frequency 17919000 Hz Master Frame Slot 9
Frequency 13276000 Hz Master Frame Slot 5
Frequency 11387000 Hz Master Frame Slot 1
Frequency 8912000 Hz Master Frame Slot 9
Frequency 6661000 Hz Master Frame Slot 5
Frequency 5652000 Hz Master Frame Slot 1
Ground Station ID 5 AUCKLAND - NEW ZEALAND UTC UNLOCKED
Longitude 174 48 35 E Latitude 37 1 10 S
Squitter Version 0
Number of frequencies 6
Frequency 17916000 Hz Master Frame Slot 12
Frequency 13351000 Hz Master Frame Slot 8
Frequency 10084000 Hz Master Frame Slot 4
Frequency 8921000 Hz Master Frame Slot 12
Frequency 6535000 Hz Master Frame Slot 8
Frequency 5583000 Hz Master Frame Slot 4
Ground Station ID 6 HAT YAI - THAILAND UTC UNLOCKED
Longitude 100 23 24 E Latitude 6 56 23 N
Squitter Version 0
Frequency 21949000 Hz Master Frame Slot 10
Frequency 17928000 Hz Master Frame Slot 6
Frequency 13270000 Hz Master Frame Slot 2
Frequency 10066000 Hz Master Frame Slot 10
Frequency 8825000 Hz Master Frame Slot 6
Frequency 6535000 Hz Master Frame Slot 2
Frequency 5655000 Hz Master Frame S lot 10
Ground Station ID 7 SHANNON - IRELAND UTC UNLOCKED
Longitude 8 55 46 W Latitude 52 43 48 N
Squitter Version 0
Frequency 11384000 Hz Master Frame Slot 2
Frequency 10081000 Hz Master Frame Slot 2
Frequency 8942000 Hz Master Frame Slot 6
Frequency 8843000 Hz Master Frame Slot 6
Frequency 6532000 Hz Master Frame Slot 10
Frequency 5547000 Hz Master Frame Slot 2
Frequency 3455000 Hz Master Frame Slot 6
Frequency 2998000 Hz Master Frame Slot 6
Ground Station ID 8 JOHANNESBURG - SOUTH AFRICA UTC UNLOCKED
Longitude 28 12 35 E Latitude 26 7 46 S
Squitter Version 0
Number of frequencies 5
Frequency 13321000 Hz Master Frame Slot 2
Frequency 8834000 Hz Master Frame Slot 6
Frequency 4681000 Hz Master Frame Slot 10
Frequency 3016000 Hz Master Frame Slot 6
Ground Station ID 9 BARROW - ALASKA UTC UNLOCKED
Longitude 156 46 46 W Latitude 71 18 0 N
Squitter Version 0
Frequency 13364000 Hz Master Frame Slot 2
Frequency 11354000 Hz Master Frame Slot 2
Frequency 10093000 Hz Master Frame Slot 2
Frequency 8936000 Hz Master Frame Slot 10
Frequency 5529000 Hz Master Frame Slot 2
Ground Station ID 11 ALBROOK - PANAMA CITY UTC UNLOCKED
Longitude 79 32 59 W Latitude 8 58 12 N
Squitter Version 0
Frequency 17901000 Hz Master Frame Slot 6
Frequency 13264000 Hz Master Frame Slot 2
Frequency 10063000 Hz Master Frame Slot 10
Frequency 8894000 Hz Mast er Frame Slot 6
Frequency 6589000 Hz Master Frame Slot 2
Frequency 5589000 Hz Master Frame Slot 10
Ground Station ID 14 KRASNOYARSK - RUSSIA UTC UNLOCKED
Longitude 92 18 0 E Latitude 56 6 0 N
Squitter Version 0
Frequency 21990000 Hz Master Frame Slot 4
Frequency 17912000 Hz Master Frame Slot 12
Frequency 13321000 Hz Master Frame Slot 8
Frequency 10087000 Hz Master Frame Slot 4
Frequency 8886000 Hz Master Frame Slot 12
Frequency 6596000 Hz Master Frame Slot 8
Frequency 5622000 Hz Master Frame Slot 4
Ground Station ID 13 SANTA CRUZ - BOLIVIA UTC UNLOCKED
Longitude 63 7 46 W Latitude 17 40 11 S
Squitter Version 0
Frequency 21997000 Hz Master Frame Slot 3
Frequency 17916000 Hz Master Frame Slot 11
Frequency 13315000 Hz Master Frame Slot 7
Frequency 11318000 Hz Master Frame Slot 3
Frequency 8957000 Hz Master Frame Slot 11
Frequency 6628000 Hz Master Frame Slot 7
Frequency 4660000 Hz Master Frame Slot 3
Ground Station ID 16 AGANA - GUAM UTC UNLOCKED
Longitude 144 48 0 E Latitude 13 28 11 N
Squitter Version 0
Frequency 21928000 Hz Master Frame Slot 1
Frequency 13312000 Hz Master Frame Slot 5
Frequency 11306000 Hz Master Frame Slot 1
Frequency 8927000 Hz Master Frame Slot 5
Frequency 6652000 Hz Master Frame Slot 1
Frequency 5451000 Hz Master Frame Slot 9
Ground Station ID 15 AL MUHARRAQ - BAHRAIN UTC UNLOCKED
Longitude 50 39 0 E Latitude 26 16 12 ;N
Squitter Version 0
Frequency 21982000 Hz Master Frame Slot 1
Frequency 17967000 Hz Master Frame Slot 9
Frequency 13354000 Hz Master Frame Slot 5
Frequency 10075000 Hz Master Frame Slot 1
Frequency 8885000 Hz Master Frame Slot 9
Frequency 5544000 Hz Master Frame Slot 5
Ground Station ID 17 CANARIAS - SPAIN UTC UNLOCKED
Longitude 15 23 23 W Latitude 27 56 59 N
Squitter Version 0
Frequency 21955000 Hz Master Frame Slot 4
Frequency 17928000 Hz Master Frame Slot 12
Frequency 13303000 Hz Master Frame Slot 8
Frequency 11348000 Hz Master Frame Slot 4
Frequency 8948000 Hz Master Frame Slot 12
Frequency 6529000 Hz Master Frame Slot 8
Old 04-19-2018, 9:37 PM
Wiki Admin Emeritus
I can't put my finger on this, but I'm pretty sure Table 49 is still in effect at most stations. As I understand it there was some initial confusion as to whether Table 50 would be rolled out to all sites, but AFAIK, that hasn't happened as yet. At least the file on the UDXF website still reflects Table 49 sites and frequencies. Perhaps the two aren't all that dissimilar - just a site name or two likely changed. I'm too close to Annapolis to even begin to see whether that station is still on the air, but I highly doubt it. As I understand it, the Annapolis site was supposed to be a test station and is not on the regular sked for either table entry. Station 11 is still Panama, I think - but I could be wrong.
Here's the UDXF website freq listing for Table 49 (it's a PDF file)
http://www.udxf.nl/Digital-aero.pdf
Unfortunately there is software out there, like Sorcerer, that is (at least the last I've been told) using a very old system table, hard coded in their software, that, while the software does decode HFDL, the sites it reports are outdated which can mislead the uninformed. There have been whispers about a Sorcerer version that does include Table 49 but where to get it (or how to fix the system table in Sorcerer itself) remains a mystery.
Old 04-19-2018, 10:04 PM
Wiki Admin Emeritus
There are several other packages that cover HFDL, but AFAIK, the .dat file that's floating around that has the Table 49 data for site decoding is only usable in the registered version of PC-HFDL.
Apart from the multi-kilobuck packages like Krypto, Wavecom and others, the other apps (besides Sorcerer) that can do it include MultiPSK and Sigmira. I don't believe either of these packages can incorporate the .dat file, but they will decode the signal. The site in my sig line has the links for both of these if you're interested
The only way to be sure which table a site is using is to wait for the full table schedule to be sent - and that happens rather irregularly, so it makes it harder to pin down
Old 04-20-2018, 10:54 AM
DaveNF2G's Avatar
It depends on where you are and what ground stations you follow. The North American stations are using Table 50 and the rest of the world is using 49. There are a few exceptions just to confuse the issue.
David T. Stark
NF2G WQMY980 KYR7128
Old 04-20-2018, 11:11 AM
Wiki Admin Emeritus
I dug this up with a little searching - the link came from the HF Underground website, and it describes in some detail how to update Sorcerer to use the current system table (which you can get, I think, from the PC HFDL Yahoo group, and it seems you need the text version). I don't use that software so I can't speak for how well it works...caveat emptor
Hike of your Life: How to display correct HFDL ground stations in Sorcerer
