NC1
I found some interference between channels 7 and 8 on the CB. I took out my shortwave radio and found the transmission to be on 27.045 MHz, which I know is an RC frequency. From what I can tell, it really sounds much like Packet at 1200 baud, or something extremely similar in nature.
The sounds were not anything for a remote control because I could hear someone answering back just above the noise floor using the same mode. I was most definitely a conversation using a digital mode. One station was very close by due to the strong solid signal, and the other was a good distance because it was barely audible. I was only using the telescopic whip on the radio, so the 2nd station still had to be fairly close but was not detectable at times.
My question is: what do I need to decode the transmission? I have a shortwave radio and a computer running Vista. Hopefully all I need is a software program and a cable plugged into my microphone jack from the radio.
Since the signal is so strong, can I hook up my computer to a HT CB (using the jacks) to transmit "KNOCK IT OFF" using Packet? lol
If I can hook it up to the CB it would be better because I do hear this from time to time on other channels, however, if all I can do is monitor and decode that would be just fine as well.
Any ideas that do not involve making new equipment purchases?
