Go Back   The RadioReference.com Forums > Service Specific Monitoring > Skip / Tropospheric Ducting Forum
Skip / Tropospheric Ducting Forum - Discussion of Skip and Tropospheric Ducting Monitoring
Old 12-14-2017, 9:48 PM
kb4cvn's Avatar
Location: Nowhere near a paved road, away from the maddening world.
Post USA's only Four Meter Amateur Radio beacon
The USA's only Four Meter Amateur Radio beacon has renewed it FCC Part-5 (Experimental) license for another two years.
Atop Apple Orchard Mountain (Bedford County, VA) in Grid Square FM07fm at a height of 4300 feet.
Callsign: WG2XPN
Frequency: 70.005 MHz CW
ERP 3kW from a Yagi aimed at 60 degrees true north. The trustee of (Brian Justin, WA1ZMS/4) advises that the beacon is operating 24/7. The beacon has been heard via multi-hop E-skip in the UK and other locations in the EU over the past few years. QSL reports are encouraged via the DX cluster or beaconspot.eu.
https://www.eham.net/ehamforum/smf/i...topic=113897.0
Original 4M posting when it went on the air. http://www.70mhz.org/index.php?categoryid=1&p2_articleid=365
Old 12-14-2017, 10:18 PM
mmckenna's Avatar
So, just for giggles, I tried out here in California with a discone and an end-fed 70 foot wire. Nothing, not that I really expected anything different.
Old 12-14-2017, 10:21 PM
Easily heard here, as well as his 2m amateur radio beacon-but after all I am in Virginia (Fredericksburg).
Old 12-14-2017, 10:25 PM
mmckenna's Avatar
Yeah, I figured I might get some off the back of their Yagi, but that would really be stretching it all the way out here. Maybe if the band was open….
Old 12-15-2017, 6:13 AM
Thanks for the heads up, will see if it can be heard at this QTH.
Old 12-15-2017, 11:04 AM
Wonder if a Baofeng's wideband FM reciever could pick it up.
Old 12-15-2017, 11:23 AM
They go down to 65 MHz but it's not likely you would be able to copy a low power CW becaon via E skip on a Baofeng.
Tom
Old 12-15-2017, 12:10 PM
Default USA's only Four Meter Amateur Radio beacon
Define low power. In the OP it says 3kW ERP
Interoperatablity is not a technology, it is an attitude!!!
Old 12-15-2017, 12:47 PM
I missed the k!
Tom
Old 12-15-2017, 12:49 PM
I missed the k!
Makes sense. If you are behind the beam, (it points towards Europe) it should be pretty easy to hear it. There will be a lobe to the rear, But probably not with a baoturd.
Old 12-15-2017, 2:38 PM
kb4cvn's Avatar
Default .MP3 audio file of the transmitted signal
Here is a .MP3 audio file of the transmitted signal. I live nine miles east of the site, and can see it out my back door.
BTW: Hams in New England have reported hearing the signal.
