The RadioReference.com Forums
-   Software Defined Radio (https://forums.radioreference.com/software-defined-radio/)
-   -   RTL2832U with HDSDR (https://forums.radioreference.com/software-defined-radio/249047-rtl2832u-hdsdr.html)
xeno194 09-15-2012 9:50 AM
RTL2832U with HDSDR
This might help some others on here getting the RTL2832U usbsdr to talk with hdsdr.
If you don't have HDSDR install you can get it here
HDSDR Homepage
If you allready have HDSDR install you just need to copy the two files in this zip and select the ExtIO_RTLSDR and your good to go.
Zippyshare.com - ExtIO_RTLSDR_GUI.zip
kilokat7 09-15-2012 11:27 AM
Mike - that sounds a whole lot easier than these (outdated now?) instructions:
Getting Started with a RTL based SDR Dongle RTL Software Defined Radio
I admit that I haven't played around with the RTL SDR for a few months now, but has something changed that has made the install process easier? I never did get it working correctly with HDSDR, though it works fine with SDR#. I may have to try again as I would prefer to use HDSDR.
xeno194 09-15-2012 11:36 AM
The only pita part is fixing the freq offset but goto a noaa freq in hdsdr.The tuned frew will be off + or - 1mhz or less.Right click on the ext io in hdsdr and input the proper freq and click set and the offset will stick. Each program has strong and weak point but i also prefer hdsdr.
Sent from my SGH-T989 using Tapatalk 2
