HDSDR v2.50
SCPD
QRT
Virginia
New version of hdsdr was just released.
Version 2.50 (30 October 2012)
- better CPU utilization
- better WFM (mono) workaround with 96kHz output samplerate
- improved image rejection
- ECSS improved
- offset per mode (SDR on IF output)
- CW-LSB for sync with analog radio
- new command line option "Path\ExtIO_xyz.DLL" for ExtIO-DLL selection
- enhanced recording scheduler
- enhanced multi-monitor support
- CW pitch frequency adjustable with mouseclick on pitch-text
alternatively with mousewheel on the pitch-text
- fixes and improvements for Omni-Rig
- some small fixes and improvements
Download it here
http://www.hdsdr.de/download/HDSDR_install.exe
kma371
QRT
Do any of these programs decode P25 audio?
KA2ZEY
Brooklyn, NY
Great news and thank you! I tried 2.5 and yes, I'm getting much better performance with my USRP B100. I notice less use of the CPU but still having major issues if I adjust the gain in EXTIO or move the 'grey' band slider in HDSDR. I loose contact with the B100 and have to restart, unplug/plug the B100 and none of those options are a guarantee of getting it online again. But thank you again for the support. Great program when working!
Best,
Ka2zey
KA2ZEY
Brooklyn, NY
I've attached 2 of the errors I get when trying to use the B100
majoco
Stirrer
New Zealand
I have been playing with HDSDR V2-50 - using it with a SoftRock fixed frequency SDR as an IF in my Kenwood R2000. Works very well - I can see almost +/- 50kHz of any HF frequency and the audio is very good. When I set it up carefully, the frequency is spot on.
However the I/Q phase/amplitude balance method to get rid of the image frequency is poor. It only works if you put the signal on the same frequency as you set the balance up on - in the instructions +/- 10kHz. Otherwise it's useless. Any chance that they can come up with an automatic method of balancing as in Rocky and SDRSharp? Looking forward to V3?
