Well I have intel dual core 3.20 ghz with 2GB of DDR3 ram and Windows7 Pro, I think that should do the job.
I am thinking that SDR Sharp would have to be routed from the speaker output of one sound card into line in on a second card where dsd would decode AP 25 and send it out to the speakers?
You Tube has videos of a lot of people who have done it but they are short on instructions on how to do it. I guess I will just plug away.
Moonbounce
You can use a program like Virtual Audio Cable (VAC) as the go-between without having to use multiple sound cards and have cables flying all over.
Dongle --> SDR Sharp ---> VAC --> DSD
So you would install VAC. Then in SDRSharp you'd set the output device to Line 1 (Virtual Audio Cable).
Then you'd set Line 1 (Virtual Audio Cable) as the default input device in Windows.
Virtual Audio Cable is the key to doing this with minimal hassle. Of course, it adds a little resource load to the system.
If you get all of that running to where audio is definitely feeding into DSD but you aren't making much sense of the decode, you should open up your task manager and watch the CPU usage while a P25 decode is happening. If it's spiking 100% CPU during P25 decode, then you've got a CPU bottleneck. The only solution for that would be more cowbell.
