You'll want two dongles for effective trunking. I've never used in digital but it works decent in analog.
Performance will suffer a little if your trunked system occupies a ranger wider than ~1mhz.
This is next on my list once I have a more powerful computer. My poor little Celeron laptop can BARELY run Unitrunker, DSD and
one instance of SDR# (and that's after all sorts of performance tweaks and killing all but the bare minimum processes and services Windows needs to run). Once I have a new i5 machine built, then I'll go for broke with 2 dongles and a full trunking setup.
So what would i use for just basic monitoring of NON trunked P25 and DMR?
Since it's semi related to this thread
, what have you found are the optimal filter/bandwidth settings for DSD? I've been using Youssef/9840 for DSD and I was getting OK P25 decoding out of it but quite by accident I bumped the bandwidth down to 3500 or so and all of a sudden DSD went from errorbars that looked like this: ====R========R==R to errorbars that looked like this: ==== and the voice quality coming out of DSD was improved greatly. Was that just a fluke or did I stumble onto something? I noticed it was hit or miss, some decodes were nearly perfect while others were garbled and completely unintelligible, but I think that was more likely due to my underpowered processor than any settings in DSD or SDR#. Thoughts?
Edited to add: Also, I've found the Filter Order setting affects DSD as well. If I leave it at 10, the trick above doesn't work, but if I set it between 40 and 60, DSD is a happy camper. Curious what others have found works best for them.
-AZ
