Sdr # won't load trunker plugin
JAMINRC
rapid city south dakota
I have been trying to load sdr # trunker plugin and sdr will load , but it doesn't show the trunker plugin on the user interface. I looked all around on the web and one article said its suppose to go in the plugins xml file. Well I did that and I kept getting error messages. The version I'm using is ver 1318. I downloaded it from the current Sdr# website. I even tried to add the line in the config file. <add key="Trunker" value="SDRSharp.Trunker.TrunkerPlugin, SDRSharp.Trunker" , But it didn't work either. Does anyone know where to place this line ? I've tried it so many times and every time I get an error message. If anyone can help it would be sure appreciated. Thanks James
BM82557
Berkeley Co WV
Go to the link that is in this post - http://forums.radioreference.com/2240485-post2.html it will have a zip file that has the updated version of the Trunker plugin that works with the newer versions of SDR#. Download that and install it. The addkey does go in the Plugin xml file and not in the config file.
JAMINRC
Thank you for the info. It appears that I had a copy of the sdr plugin from another sdr version, well I deleted it and did a registry scan and removed remnants of the other version. It worked I got it running, but now I have a problem with the dsdplus. I can't get it to work.
