  #1321 (permalink)
Old 10-17-2017, 6:15 AM
Originally Posted by rylvir View Post
Just reinstalled OP25 after a years hiatus, currently using boatbod branch on Linux Mint 18.2. So rx.py is new to me, and thanks to this thread I have it up and running! No errors, great sounding audio on a local Phase 1 system. Resources are quite a bit lighter on these new versions, and I really like the audio. Is there any new tricks to pipe the audio from OP25 > darkice > Broadcastify? I used to use pavucontrol, and just direct all audio over to darkice with success, but that isn't working anymore.
Linux Mint 18.2
The pulse audio method should still work for darkice, but I recall you need to go in to the pulse audio mixer when darkice is running and put a check in a box to make the monitoring work correctly.
Personally I use straight alsa with an aloop (loopback) device defined in /etc/asound.conf. That way other system sounds don't inadvertently get picked up and mixed in with your broadcastify stream. PM me if you want a copy of the config file.
  #1322 (permalink)
Old 10-19-2017, 7:02 AM
Originally Posted by royldean View Post
Awesome. I will try this afternoon. Assuming all other instructions the same (this is a huge thread so I may have missed this somewhere else)?
Thanks!
I have found that boatbod's install script works great as well. (It's in the root of his github after cloning it)
  #1323 (permalink)
Old 10-19-2017, 11:13 AM
The credit for that install script goes to Max.
For anyone interested, I have merged the latest changes to the osmocom max branch into my op25 github fork and added the ability to dynamically turn on and off the various plots (fft, constellation, symbol & datascope). These are controlled from the terminal window by pressing the 1, 2, 3 & 4 keys.
1 = fft
2 = constellation
3 = symbol
4 = datascope
Presently it is only possible to enable one plot at a time. Once I figure out how to track and untangle the gnuradio inter-block connections, I will see about making them operate simultaneously.
Graham
  #1324 (permalink)
Old 10-19-2017, 4:43 PM
Hello, I have been playing with the older version of OP25 (scope.sh) and was going to try out the max branch version. I am setting up a new box with 16.04 and running into "E: You must put some 'source' URIs in your sources.list" error when running "apt-get build-dep gnuradio". Is Ubuntu 14 still the only way to go, or is 16 usable?
I did use the thread search and found a reference to this error and I didn't understand adcockfred's response. 2-5 clone command.
  #1325 (permalink)
Old 10-19-2017, 11:38 PM
EDIT: Finally realized I was in the wrong directory LOL.
  #1326 (permalink)
Old 10-20-2017, 6:17 AM
The max branch and my fork both work fine on Ubuntu 16 as well as Raspbian Jessie/Stretch etc.
  #1327 (permalink)
Old 10-20-2017, 8:48 AM
So now that boatbod has single handedly got op25 running on my ubuntu box, I have a general follow up question. Can I force op25 into only monitoring certain talkgroups? Also, is there a way to force it to give priority to certain talkgroups? I realize this may be a stretch with a single rtl-sdr (how is it supposed to re-tune based on a control channel if it is currently monitoring a transmission that forced a re-tune beyond the range of the control channel, correct)?
  #1328 (permalink)
Old 10-20-2017, 11:20 AM
Monitoring "only" specified TGIDs is easy. Populate a file containing numeric TGIDs (one per line) and save this as "tgid.wlist" (or whatever name you want), then add the filename to the appropriate position in your trunk.tsv config file.
e.g. "talbot-leo.wlist" as seen in my config fie.
Code:
"Sysname"	"Control Channel List"	"Offset"	"NAC"	"Modulation"	"TGID Tags File"	"Whitelist"	"Blacklist"	"Center Frequency"
"FiRST-TALB"	"773.843750"	"0"	"0x4a6"	"CQPSK"	"first.tsv"	"talbot-leo.wlist"	"first.blist"	"773.84375"
  #1329 (permalink)
Old 10-20-2017, 12:05 PM
does the addition of that .wlist EXCLUDE those tgid's? Because I just restarted with a new list and now I'm hearing only from tg's that I don't want to hear.
[edit] Doh! missed a column and added it to "blacklist"!!!
  #1330 (permalink)
Old 10-20-2017, 2:24 PM
is there a command line argument that increases audio volume? I have to crank my volume all the way up to hear.
  #1331 (permalink)
Old 10-20-2017, 2:45 PM
If you are running 14.04 there is a check box to increase volume more than 100% under settings in Ubuntu 14.04
  #1332 (permalink)
Old 10-20-2017, 6:14 PM
You can run "alsamixer" on the command line and that lets you adjust levels.
  #1333 (permalink)
Old 10-20-2017, 8:19 PM
Sorry, I hadn't noticed it until I cloned your github so I figured it was yours. My apologies.
  #1334 (permalink)
Old 10-21-2017, 6:53 PM
Trying to run cmake ../ comand and get this error any ideas
-- The CXX compiler identification is unknown
-- The C compiler identification is GNU 5.4.0
CMake Error at CMakeLists.txt:2 (project):
No CMAKE_CXX_COMPILER could be found.
Tell CMake where to find the compiler by setting either the environment
variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
to the compiler, or to the compiler name if it is in the PATH.
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Configuring incomplete, errors occurred!
See also "/home/aaron/op25/build/CMakeFiles/CMakeOutput.log".
See also "/home/aaron/op25/build/CMakeFiles/CMakeError.log".
  #1335 (permalink)
Old 10-21-2017, 7:37 PM
Unmet dependency; in this case you probably don't have a fully installed build-essential package.
sudo apt-get install build-essential
  #1336 (permalink)
Old 10-21-2017, 10:00 PM
Now i get this when trying to run osmocom_fft
linux; GNU C++ version 5.3.1 20151219; Boost_105800; UHD_003.009.002-0-unknown
File "/usr/bin/osmocom_fft", line 34, in <module>
from gnuradio import blocks
File "/usr/lib/python2.7/dist-packages/gnuradio/blocks/__init__.py", line 34, in <module>
from stream_to_vector_decimator import *
File "/usr/lib/python2.7/dist-packages/gnuradio/blocks/stream_to_vector_decimator.py", line 23, in <module>
from gnuradio import gr
File "/usr/lib/python2.7/dist-packages/gnuradio/gr/__init__.py", line 44, in <module>
from top_block import *
File "/usr/lib/python2.7/dist-packages/gnuradio/gr/top_block.py", line 30, in <module>
from hier_block2 import hier_block2
File "/usr/lib/python2.7/dist-packages/gnuradio/gr/hier_block2.py", line 25, in <module>
import pmt
File "/usr/lib/python2.7/dist-packages/pmt/__init__.py", line 58, in <module>
from pmt_to_python import pmt_to_python as to_python
File "/usr/lib/python2.7/dist-packages/pmt/pmt_to_python.py", line 22, in <module>
import numpy
ImportError: No module named numpy
  #1337 (permalink)
Old 10-22-2017, 6:52 AM
import pmt
import numpy
Python install is broken.
What happened? Thought you had op25 successfully built/running and just needed to get the tuning dialed in?
  #1338 (permalink)
Old 10-22-2017, 9:46 AM
Have it running on my computer Installing op25 on a laptop running mint 18.2 trying to get it to work kind of dificult
  #1339 (permalink)
Old 10-22-2017, 12:14 PM
I don't recall having that much of an issue when I installed Mint, but that was a while ago...
Try this:
sudo apt-get install python2.7-dev
or maybe this:
If it fails you can always do this to fix the numpy error, but I wonder what else is missing.
sudo apt-get install python-numpy
  #1340 (permalink)
Old 10-22-2017, 12:24 PM
Default New gnuplot mode
Another day, another update This time I have something that I hope will help with dialing in the fine tuning; it's a new plot mode showing the output of the mixer - in other words just the portion of the signal that is going to be used by the c4fm/cqpsk demodulator.
When tuning is adjusted correctly, you should see a nicely symmetrical upside-down "U" centered perfectly at zero. If tuning is off, the envelope will be shifted to one side or the other and will look distorted. Adjust ppm correction and/or fine-tune to make it look good, then use these values in your rx.py command line parameters.
Mixer plot can be initiated either by pressing "5" from the terminal screen, or using the command line parameter "-P mixer".
The code for this change has been committed to my github. Perform a "git pull" to get the changes if you have already cloned the repo.
NOTE: first screen shot shows good tuning, second shows tuning significantly offset
