  #1821 (permalink)
Old 01-24-2018, 6:50 PM
Originally Posted by WX4JCW View Post
I can’t get the TG aliases to display is that normal?
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
Have you populated the tgid-tags.tsv file and set the file name in trunk.tsv?
Format is:
Code:
tgid#TABText tag stringTABprio#
  #1822 (permalink)
Old 01-24-2018, 7:00 PM
WX4JCW's Avatar
Yes named it Portland.tsv and referenced it in trunk.tsv
Jason WX4JCW
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
SDS100,XPR7550,SDR
  #1823 (permalink)
Old 01-24-2018, 8:03 PM
Jason WX4JCW
You need to make sure there is precisely ONE TAB character between the tgid and the tag text string. If you specify a trunk priority that has to be ONE TAB after the end of the text string.
  #1824 (permalink)
Old 01-24-2018, 8:14 PM
WX4JCW's Avatar
got that, it was corrupted, fixed it
SDS100,XPR7550,SDR
  #1825 (permalink)
Old 01-24-2018, 10:26 PM
@boatbod was looking at your code. is there a function somewhere that I can build an additional config file using .tsv file to place and match source id's of the radios with Common Names?
  #1826 (permalink)
Old 01-25-2018, 6:27 AM
Guys, is it possible to have RX record conversations by talkgroup ID by streaming them to a wav/mp3? I'm thinking every time a specific ID chatters this could be appended to an audio file.
Also, have any of you looked at VLC. I'm wondering if it's possible to have SDR running on my laptop at home, and remotely connect to the audio via VLC on my iPhone?
Anyone done anything like the above?
  #1827 (permalink)
Old 01-25-2018, 7:38 AM
Anything is possible but it's not there at present. There are a couple considerations that spring to mind if you wanted to implement the feature:
- similar to the trunk tags, source names lookup table would likely best reside within the trunking module. The data passes from trunking to terminal via a json-encoded message. At present it's pretty simple: "srcaddr=12345". The logical addition would be to add a new parameter "srcname=abcdef" to the existing message.
- the terminal.py module is pretty dumb and does not have access to any lookup tables. All it does is make requests and receive info via json messages. Screen space for additional data display is at a premium and it's a royal PITA to make everything move and revalidate when the terminal is resized. Accidentally attempting to set a string longer than the defined text window is a really easy way to crash ncurses!
  #1828 (permalink)
Old 01-25-2018, 7:56 AM
There is a remote audio capability already, but i's raw UDP not VLC. On the sdr machine you set up the command line with "-V -2 -w -W hostname" (dropping -U) and then on the remote player you run the command "./audio.sh"
The recoding capability you describe may already be provided by a different application called trunk-recorder.
  #1829 (permalink)
Old 01-25-2018, 7:59 AM
Yeah I saw it was using json encoded streams but wasn't exactly sure how that was working. I'm going to give it ago and have a look at it and see if I can't get this to work. If I do somehow manage to get this working I'll be sure to issue a pull request for a merge on your repo.
  #1830 (permalink)
Old 01-25-2018, 10:09 AM
trunking.py
line 744 [ def to_json() ] - where the .json messages are formulated and you'd need to add the extra srcname parameter.
line 704 [ def setup_config() ] - probably where you'd need to add code to read in a srcaddr-srcname mapping table.
You'd probably also have to extend trunk.tsv format so you can name your new mapping table. Make sure it's optional and backward compatible so you don't break existing config files.
terminal.py
line 84 [ def setup_curses() ] - the "status1" window used for srcaddr
line 110 [ def resize_curses() ] - resizing logic for "status1" window
line 226 [ def process_json() ] - where srcaddr gets unpacked and put on the screen
  #1831 (permalink)
Old 01-25-2018, 10:12 AM
trunking.py
terminal.py
Thanks for this this will be helpful. I'll dig in when i have some time.
  #1832 (permalink)
Old 01-29-2018, 12:57 AM
SDRPlayer's Avatar
I hope this is the right place to post, i want to thank Boatbod for his work on the project. I had no issues getting his OP25 up and running on Mint 18.3 cinnamon 32-bit. Also thanks to Broadband for his tutorial a few pages back on how to generate the .tsv file with Libreoffice (i would have surely got stuck otherwise).
  #1833 (permalink)
Old 02-06-2018, 6:58 PM
Is this specific to your repo?
Also is there any way for the 2 repos to coexist on the same machine for testing both?
FYI I had a friend over the other day who has a real radio on the systems I'm monitoring - we did a comparison and op25 sounded almost exactly as perfect. Great stuff!
  #1834 (permalink)
Old 02-06-2018, 8:03 PM
The remote-udp code is common to both repos; it was one of Max's main changes when he moved away from scope.py and implemented rx.py.
You can co-exist both repos at the same time, but only one can be actively operational at a time. The way I do it is by cloning into specific subdirectories, then symlinking the one I was to use at any given point. Once you move the sym link you just need to repeat the "sudo make install" before you run the application.
git clone op25.osmocom.org ~/op25.max
rm ~/op25; ln -s ~/op25.max ~/op25
cd op25
mkdir build; cd build
cmake ../
etc etc
git clone https://www.github.com/boatbod/op25 op25.boat
rm ~/op25; ln -s ~/op25.boat ~/op25
cd op25
etc etc
  #1835 (permalink)
Old 02-08-2018, 3:10 AM
From this day forth, it shall be known as the “Boat” fork lol.
  #1836 (permalink)
Old 02-08-2018, 6:05 AM
As long as it doesn't have a hole in it
  #1837 (permalink)
Old 02-09-2018, 7:25 PM
Default install error
Getting this error on utuntbu 17.10 what is causing this gnu radio is installed
Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
-- Could NOT find GNURADIO_RUNTIME (missing: GNURADIO_RUNTIME_LIBRARIES)
-- Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
-- Found CPPUNIT: /usr/lib/x86_64-linux-gnu/libcppunit.so;dl
CMake Error at op25/gr-op25/CMakeLists.txt:102 (message):
GnuRadio Runtime required to compile op25
  #1838 (permalink)
Old 02-09-2018, 7:30 PM
dseven's Avatar
Try 'sudo apt-get install pkg-config' first.
  #1839 (permalink)
Old 02-09-2018, 8:41 PM
Thanks that was it wow that was fast lol i owe you a beer
  #1840 (permalink)
Old 02-11-2018, 11:02 PM
WX4JCW's Avatar
alright i just did a dual boot install of ubuntu to get rid of virtual box, install of boatbods branch went well
SDS100,XPR7550,SDR
