Boatanchor
- Joined
- Jul 17, 2011
- Messages
- 991
After using my Airspy for a few months I plugged in a USB lead one day and proceeded to see the USB socket dissapear inside the unit's case. On opening the case, I discovered that the micro USB socket had fallen off the PCB.
The micro USB socket contacts are surface mount soldered to the PCB while the socket itself is secured (supposedly) to the PCB via two small side case/shield pins.
The two socket case pins on my unit were 'dry' soldered to the board and this eventually caused the socket to fail since all the stress of plugging in and unplugging cables, was eventually placed on the 5 SMD contact pins.
This is a warning to all Airspy owners...
Take the time to pull your unit apart and have a look at the micro USB socket (before it fails).
Check the soldering on the socket's mounting pins and possibly even consider using some form of additional bracing. But, be carefull!! That socket is fragile and if you damage it, good luck repairing it.
I ordered 5x replacement micro USB sockets, since 2 of the 5 pins had broken off the original socket.
I damaged 2 new sockets trying to SMD mount the new socket to the PCB, using a hot air re-work station. I succeeded on the 3rd socket but even with the right hot air gear, it is a pig of a job to replace by hand.
