Hi:
I've searched the forums and haven't found much. In the past, I've owned two Winradio G31DDC receivers. Although I found them excellent, I'm an active ham so I sold them both to finance more ham gear.
As it turns out, I've accomplished many of my goals in amateur radio, so I'm back to listening more than taking an active part. Because I am not as enamored with radio as I once was, I don't want to spend an arm and a leg. I would also like the option of using the receiver I get as a panadapter for my transceiver (I have the option on my rig). I've considered an LP-Pan or even a Elecraft P3, but I would like to occasionally be able to monitor (listen to) the bands, so it has to be a receiver.
Any thoughts on the Cross County Wireless 4+? Is there another SDR I should be considering in that price range? Remember, it will serve double duty as a panadapter for my transceiver and I don't expect it to be in the same quality range as the Winradio, which is fine.
Hope I haven't been redundant.
Thanks.
Thanks.
