moonbounce
- Joined
- Nov 5, 2002
- Messages
- 1,397
I came across this fantastic super simplistic radio receiver software by Google Chrome for RTL SDR dongles. It has AM, NFM, WFM, USB and LSB. You can set the stepping frequency to any value, you can save frequencies ( or presets ) while it won't scan them it allows you to select them manually. If you have an upconverter to go along with your dongle you can scan 0 to 30 mhz as it has an upconverter for frequency off set. The frequency range is unlimited as far as I can see.
The only downside I see is that you can't pipe your signal to DSDplus to decode digital. So anyways here is the link if you want to give it a shot.
https://chrome.google.com/webstore/...ajkghmifldohpo?utm_source=chrome-ntp-launcher
All you have to do is launch the app and it will be on your desktop,
Moonbounce
Moonbounce
