elitedata
there needs to be an option for the user to set the application priority level.
every time the application is started, it starts with process priority of 24 (realtime) and i am forced to change it through task manager/process explorer to a priority level of 8 (normal).
i have tried the commands in a desktop shortcut relevant to my installation, for example:
cmd.exe /c start "SDRSharp.exe" /normal "C:\SDRS\SDRSharp.exe"
yet, starting the application with these changes still shows the process priority at 24.
i would like the program to start at process priority 8 (normal), why ?
if the program suddenly starts to pull massive amounts of CPU time due to a program fault, it leaves no free CPU time for anything else including critical processes for the operating system due to its process priority level being at 24, this has happened once already and almost leaves you no choice but to hard-reset the PC (due to 100% cpu use).
this is on a windows 7 ultimate x64 platform (fully updated to date).
i did not see another way besides IRC and an email to post this information to the airspy.com website since that is where i downloaded SDRSharp.
i completely understand the reason why the application starts with a priority level of 24 but there are some cases where it is not actually needed and works the same at a normal process level.
