Hi all, Total noob here looking for some advice on running dual rtlsdr dongles on 1 PC & listening to 2 separate frequencies at once. I will try explain best I can.
I was using unitrunker to listen to local police on AP25 Digital but they have just gone encrypted so that's now useless, What I'm currently doing is using 2 rtlsdr dongles & listening to 2 separate frequencies for local fire department (both rural analogue frequencies) by creating 2 voice receivers with unitrunker (1 receiver for each rtlsdr device) & playing both receivers at the same time so I can monitor both frequencies at the same time thru pc speakers.
Now here's my dilemma, Is it somehow possible either with unitrunker or another sdr program to be able to set 1 of the 2 frequencies i'm tuned too as a Priority channel so that they both don't overlap thru pc speakers if both frequencies happen to broadcast at the same time? I tried messing with the 'rank' function of unitrunker but doesn't seem to work across multiple voice receivers (only for multiple VCO's on 1 receiver) & the 2 frequencies are further than 3mhz apart so can't use 1 dongle (I don't think).
I would like the software to work like my old-school analogue scanner where I could scan multiple stored frequencies & have 1 channel set as priority so it detects any broadcast & locks onto it, then returns to scanning once broadcast finished?
I've also thought about some sort of PC Audio program that could possibly 'auto mute' a Virtual Cable 2 if it detects any sound via Virtual Cable 1 (if that makes any sense?). That way I could output 1 frequency to Virtual Cable 1 & the 2nd frequency to Virtual Cable 2 via unitrunker & when sound is detected on Virtual Cable 1 the software will detect & mute Virtual Cable 2 as to stop overlapping voices thru the pc speakers.
I have tried googling & reading many threads but finding little information & not sure if i'm just missing something simple I could do or If I have no option but to manually mute each receiver when the other is broadcasting.
Any help, ideas or some direction on what I could do to accomplish this would be greatly appreciated.
Thank you RR community.
