78turbo
First, I would like to thank all those who contributed to the other OP25 thread that turned into a long read with tons of information. It has given me the needed push to build a dedicated Linux system to work with it. I have it installed and running after a few long days of "Linux Coding" but cannot figure out how to get the trunking working and voice channels to work properly. I am getting errors when starting the program that I have not been able to resolve.
bryan@bryan-MP061 ~/pybombs/src/gr-op25/op25/gr-op25_repeater/apps $ ./scope.py --args 'rtl=0' -N 'LNA:35' -f 773.48125e6 -S 2400000 -q 46 -v 10 -V -2 -T talkgroups.tsv
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.git-119-g42a3eeb6
gr-osmosdr v0.1.4-67-gac15e789 (0.1.5git) gnuradio 3.7.10git-86-gfe823d38
built-in source types: file osmosdr fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy redpitaya
Using device #0 Realtek RTL SN: 0000002
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gain: name: LNA range: start 0 stop 0 step 0
setting gain LNA to 35
supported sample rates 250000-2560000 step 24000
Using Volk machine: avx_64_mmx
set_center_freq: 773481250
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail: pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
gr::log :INFO: audio source - Audio sink arch: alsa
File "./scope.py", line 2751, in <module>
app = stdgui2.stdapp(p25_rx_block, "APCO P25 Receiver", 3)
File "/home/bryan/target/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 46, in __init__
wx.App.__init__ (self, redirect=False)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in __init__
self._BootstrapApp()
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/home/bryan/target/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 49, in OnInit
frame = stdframe (self.top_block_maker, self.title, self._nstatus)
File "/home/bryan/target/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 76, in __init__
self.panel = stdpanel (self, self, top_block_maker)
File "/home/bryan/target/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 98, in __init__
self.top_block = top_block_maker (frame, self, vbox, sys.argv)
File "./scope.py", line 224, in __init__
self.open_usrp()
File "./scope.py", line 1118, in open_usrp
self.__set_rx_from_osmosdr()
File "./scope.py", line 867, in __set_rx_from_osmosdr
self.__build_graph(self.src, capture_rate)
File "./scope.py", line 314, in __build_graph
self.trunk_rx = trunking.rx_ctl(frequency_set = self.change_freq, debug = self.options.verbosity, conf_file = self.options.trunk_conf_file, logfile_workers=logfile_workers)
File "/home/bryan/pybombs/src/gr-op25/op25/gr-op25_repeater/apps/trunking.py", line 509, in __init__
self.build_config_tsv(conf_file)
File "/home/bryan/pybombs/src/gr-op25/op25/gr-op25_repeater/apps/trunking.py", line 569, in build_config_tsv
nac = int(fields['nac'], 0)
KeyError: 'nac'
I have searched for this error but I'm unable to find a solution. Any help is greatly appreciated.
I am able to decode the CC of this site without any issues and all the screens appear as they should without the trunking stuff enabled.
self.open_usrp()
KeyError: 'nac'
