I recently started using Op25 to monitor a simulcast P25 system in my area. While I have it working for the most part, I'm still having a few problems. The main problem I'm trying to troubleshoot is:
I'll be scanning through my talkgroup whitelist, I'm receiving transmissions just fine, I'll notice I haven't heard anything in a while and look over at Op25, the UI is stopping on active TGs & the terminal window that op25 was launched from is scrolling the tell tale lines indicating decoded transmissions, but I'm not hearing any audio. If I click on another tab (I've been told to leave Op25 on the Constellation tab for my particular p25 system, unless I'm checking something) such as Datascope, and then back to Constellation, this almost always restores audio. (and then the problem happens again).
Any ideas whats going on here?
