I've been able to set get OP25 up and running on a dedicated Linux machine using the instructions from the VM thread. I've tried to use the -O flag to route the output audio to a non-default sink but when I do I get Invalid Argument error when I use either a plughw or hw option. The app will run just fine with either no argument for -O, or "pulse" or "default" as arguments.
It does look like it is successfully finding audio devices, if I put in a non-existent sink, say 7,0 it will spit out a different "not found" error.
I opened up the p25_decoder.py file and noticed that there is a commented out line which sets the default output value to "plughw:0,0" maybe this is a known issue? I've done a bunch googling without any success. You guys all seem to have a lot more experience with this than I do. Any thoughts?
$ ./scope.py --args rtl=0 -N LNA:30 -f 460.50000e6 -S 2400000 -q 37 -v 10 -o 5000 -T trunk.tsv -O plughw:1,0
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.000.git-249-gef57ffcb
gr-osmosdr v0.1.4-72-g164a09fc (0.1.5git) gnuradio v3.7.10-1-ge55666b7
built-in source types: file osmosdr fcd rtl rtl_tcp uhd hackrf bladerf rfspace airspy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
gain: name: LNA range: start 0 stop 0 step 0
setting gain LNA to 30
supported sample rates 250000-2560000 step 24000
set_center_freq: 460505000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail: pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
gr::log :INFO: audio source - Audio sink arch: alsa
gr::log :ERROR: audio_alsa_sink0 - [plughw:1,0]: snd_pcm_sw_params: Invalid argument
File "./scope.py", line 2751, in <module>
app = stdgui2.stdapp(p25_rx_block, "APCO P25 Receiver", 3)
File "/usr/local/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 46, in __init__
wx.App.__init__ (self, redirect=False)
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in __init__
self._BootstrapApp()
File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/gnuradio/wxgui/stdgui2.py", line 56, in OnInit
frame.top_block().start ()
File "/usr/local/lib/python2.7/dist-packages/gnuradio/gr/top_block.py", line 109, in start
top_block_start_unlocked(self._impl, max_noutput_items)
File "/usr/local/lib/python2.7/dist-packages/gnuradio/gr/runtime_swig.py", line 3668, in top_block_start_unlocked
return _runtime_swig.top_block_start_unlocked(*args, **kwargs)
RuntimeError: audio_alsa_sink"
