Hello all!
I currently have a setup of SDR# running with Unitrunker being fed the audio which is controlling SDRSharp. I used this for reference: https://sites.google.com/site/policescannerhowto/
So every little thing has been working just as I believe it should...except for the fact that I have not been able to actually hear the audio while DSD+ is decoding. I have been able to press the 'R' key to record the raw audio being decoded, and I heard voices, so I know everything up to the point of hearing the audio is running smoothly.
I have done just about everything I can think of in regards to certain parameters in the DSD+ commands, iv'e also made sure that all the virtual cable stuff is set up as it should be(not that I think it's part of the problem if i'm able to record audio).
I cannot figure out why I can't hear the decoded audio live, instead of recorded. Please help!
Thanks in advance.
Thanks in advance.
