  #21 (permalink)
Old 02-24-2017, 1:02 PM
I do not understand what I am messing up. Other users with my dongle and operating system can get Unitrunker to log with my same settings, but I cannot and continue to get the "Cannot open!" error message.
I am able to get sdr stick to function with SDRsharp and SDRsharp/freq mgr combo software without problems.
Can anybody please help me.
  #22 (permalink)
Old 02-25-2017, 5:55 AM
Seņor Member
Hello CPAJ;
The program has a bug in how it enumerates USB devices looking for compatible Realteks. It works for most hardware out there. The bug is most obvious when using an external USB hub. The program can't see what's behind the hub to open the device.
Some PC manufacturers build a single USB hub onto the motherboard instead of separate, directly addressable USB ports. I do not know if this is the actual issue here but is I think a likely guess.
  #23 (permalink)
Old 03-09-2017, 12:45 PM
Default Reply
Unitrunker - Sorry, I have been away and distracted for a week or two but I just saw your reply. If this is the case it would make the most sense.
My final question is if I bought a higher end "2nd gen" dongle/stick, would I experience the same issues on this same PC or would it be worth trying?
Thanks again everyone.
  #24 (permalink)
Old 03-11-2017, 3:56 PM
Seņor Member
Originally Posted by CPAJ View Post
My final question is if I bought a higher end "2nd gen" dongle/stick, would I experience the same issues on this same PC or would it be worth trying.
I don't think swapping RTL sticks would make a difference here.
  #25 (permalink)
Old 03-11-2017, 11:50 PM
me1900's Avatar
I would use 1 rtl-sdr per hub. A hub can have any number of ports. Osmocom and rtl-sdr redditt tells us never to connect the rtl-sdr dongles to external USB hubs. The reason is beyond me. It seems to work better using just USB extension data cables directly from the laptop or desktop's USB ports.I will go so far as to say Unitrunker is right for not seeing the additional dongle if yours is on an external USB Hub.
These are software defined radios. They are not memory sticks, cameras, mp3 players, etc. They use a lot of system resources and must have separate hubs.
  #26 (permalink)
Old 03-12-2017, 1:28 AM
Guess I should stop running four dongles on one hub...
  #27 (permalink)
Old 03-12-2017, 3:01 PM
dave3825's Avatar
Originally Posted by Unitrunker View Post
Hello CPAJ;
lol
What is your setup? Pc, laptop, hub? How many usb ports does your machine have? How many are in use?
I have been running 2 Realtek dongles with Unitrunker for a long time, on an ext hub. The ext hub I use is a 5 port made in china no name hub, but it's powered from an external power source, not the pc's usb power. In addition to the 2 dongles running, I also have my bcd436 connected to Proscan (logging 24/7) , and a TU-S9 USB to Serial converter to program or log with my br330t because my pc lacks a Serial port. So that's 4 items running off the hub. At times, while 4 ports are in use, I also move pictures from my digital Nikon via a usb sd card reader...
If your trying a hub, is it a powered hub with a external power source? I was never able to get 2 dongles to run on a non powered or self powered (pc powered) hub. It did the exact same thing starting for a half second and could not open. You may not have enough power going to your usb.
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
  #28 (permalink)
Old 03-13-2017, 4:51 PM
In my scenario, I AM connecting the sdr directly to the laptop's port without an external hub. What unitrunker is saying is, with some machines, the laptop is built with an internal hub instead of a separate port for each of the laptop's usb inputs. So, in my case, my laptop seems to be one of the machines built this way - thus, sdr in unitrunker will not work attached to my usb input, external hub or not.
  #29 (permalink)
Old 03-13-2017, 4:55 PM
Originally Posted by dave3825 View Post
lol
So is it that my computer is one that unitrunker program does not play nicely with due to it's internal hub (as opposed to multiple internal ports)? I get the same error message when it connects to any of the three laptop ports. The stick will work with sharp, and other usb attachments work like a mouse or inline radio with unitrunker via usb, just not my stick and unitrunker. Reference the entire thread if you think you can offer any assistance, but I believe we have come to the conclusion that it is a lost cause with my pc.
  #30 (permalink)
Old 03-13-2017, 5:35 PM
dave3825's Avatar
You don't by chance have an external usb hub laying around?
  #31 (permalink)
Old 03-15-2017, 12:00 PM
Unfortunately I do not. Thanks for the input but, in time, I will have to get a dedicated computer for sdr & unitrunker configurations. In the mean time, unitrunker works fine solo with the pro651 and the sdr works fine solo with sharp.
  #32 (permalink)
Old 07-13-2017, 3:41 PM
Did you end up finding a solution? I have the same device purchased off of ebay, and while it works just fine in SDR#, it immediately stops with the same error you were experiencing. Interestingly enough, I have another similar SDR device (RTL-SDR, the metal one) and it starts fine in Unitracker. Both show up as RTL2832U devices, and I know both aren't in use before trying to start them, yet the one fails to start.
  #33 (permalink)
Old 07-14-2017, 10:21 AM
So my buddy has another one of those cheap RTL2832U+R820T SDRs purchased off of ebay that looked identical to mine on the outside and it works fine in Unitrunker, but one thing I noticed was that the LED light on mine was white while his was blue. Curious, we opened up both and found that they were different inside (see attachments). I don't know if mine is crippled in some way, or just confusing Unitrunker in some way. Like I said, it works fine in SDR#, but Unitrunker won't open the device.
  #34 (permalink)
Old 07-14-2017, 8:09 PM
1: Stop wasting money on those cheap MCX-equipped dongles.
2: Since you have it apart already, tell us what tuner chip it has.
  #35 (permalink)
Old 01-13-2018, 7:48 PM
WX4JCW's Avatar
did we ever find a solution to this, now i am having it with my new laptop
Jason WX4JCW EMD/FF/EMT RET
Like Johnny Cash's Song I've been everywhere man, ive been everywhere and monitored it
Unication G4, BCD536HP, SDR
  #36 (permalink)
Old 01-15-2018, 10:21 AM
Default Same USB problem
Add me to the group of people not able to open one of my tuners. My setup is a Patriotwaves Skyfall radio box with two receivers in it. I am able to run both receivers at the same time on SDRTrunk, and HDSDR, but when I use UniTrunker, the program refuses to open my second receiver. I am using a a Dell Latitude E5430 with an I5 processor. I believe UniTrunker's theory of a single USB hub on the motherboard causing the problem is correct, I am able to use both receivers on my desktop computers with UniTrunker with no problem. UniTrunker, is there any chance you will release an enhancement to correct this problem? I really like using UniTrunker and having it work on my laptop is key for monitoring systems out of my area when I am traveling.
  #37 (permalink)
Old 01-15-2018, 11:53 AM
IMO, you're making problems for yourself. That product has some sort of USB hub in it and it's limiting your options. If you had two discrete dongles with cables, you could plug them into two USB ports on your PC and you'd likely have no issues.
FYI, the Unitrunker author no longer monitors this forum.
