Chesterdrawers
Is anyone able to assist me in acquiring the original Fast Scanner plugin for SDR# v1361?
Regards.
C
Regards.
C
Regards.
C
I think he is talking about the Freq Scanner plugin from the Russian developers website
her is a link to what I think you are after, it is in Russian just need to translate.
Сканер + поиск новых частот.
It's the version that has the user defined scanning range that opens in a separate pop up window to SDR#, as shown in this video - https://m.youtube.com/watch?v=BNi86E6MZOY
So it is just basically a scanner the same as the Frequency Manager and Scanner plugin?...
The one you linked to youtube is what happens when I try the one Moonbounce posted. It does have a pop out window that lets you set scan ranges, freq lower, freq upper, step size, bandwidth It has this on the scanner popout
It does not have the lock, unlock squelch,and volume on the pop out shown here
It has what's shown below.
I have been looking for the one that has the lock, unlock squelch,and volume on the pop out.
Wondering if it was changed since it was posted in 2014
The one that's in the bottom of post 10 is this,
http://rtl-sdr.ru/uploads/download/freqscanner.zip
Being that you cant get to the site, if the above does not work, try this,
TinyUpload.com - best file hosting solution, with no limits, totaly free
I wonder if your older versions are the ones I'm after?I checked my pc and I have some older versions of the zip file from 2014 and 2015.
Unfortunately I can't access the link that Moonbounce has posted (and that's on three different computers). I wonder if access to it is blocked from the UK, as I just get a blank page.
dave3825 would you be able to forward me the plugin that you have showed in your previous post please?
Here is the oldest version I have, it is from 03032014 - TinyUpload.com - best file hosting solution, with no limits, totaly free
