Old 07-13-2017, 8:01 AM
Default Unitrunker Help
Am I doing something wrong?
I setup first dongle and entered control channel, Unitrunker finds trunked site 22 but all the frequencies are different than listed on web site.Is this why I cant hear anything from second dongle.
Old 07-22-2017, 8:14 PM
dave3825's Avatar
Does your dongle need a ppm adjustment?
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
Old 07-22-2017, 9:33 PM
Seņor Member
There isn't enough information to answer the OP's question.
What system are you monitoring?
What website?
What frequencies?
As Dave points out, did you calibrate both Realtek SDRs?
Is the second SDR VCO set to a voice role?
What is the voice role VCO's listening threshold?
Old 10-15-2017, 3:22 PM
Default Sorry so late
I Realized that my control channel was entered right at 142.440, I then had to manually enter all other channels, as they came up with 000.000 .I can now see activity, I didnt know that Trunking was on more than 800mhz.
so much to know
I apologize for late response, I used my secondary email as a username on radioreference.
that is why no response.
https://www.radioreference.com/apps/db/?siteId=1279
Also I think in need better antenna for my dongles, My BC895XTL will find more frequencies with antenna on my TV tower. but all are DMR, NDXN or Apco p2 ..thats why I got into the SDR dongle method.
