Isn't all of this covered in the change log?
BTW, I see two examples of scan list entries. Yours (old and new) don't look like them.
I got those from the fmp.txt file,shown below starting with scanning, not DSD+ 2.18 New Features. I must have missed that. I have not played with the scanner feature in a while.
This is where I got the 2 formats.
scanning
FMP can (slowly) scan frequencies
a frequency list, one frequency per line, should be placed in a file
named FMP.ScanList . he format of each line is: frequency mode description
example:
450.1250 TIII Acme Radio
And this, and even tho it's for the csv file, I used the format in the FMP24.ScanList file and it scans, stays on freq when there is activity, and resumes scanning when the transmission is over.
FMP Frequency Lists
Every time FMP is retuned, FMP will search the CSV files specified in FMP.cfg
for matching in-range frequency records. The CSV files can be created from
government data sources or Internet sites.
Each line in the files holds one TX frequency record or a record for
a TX/RX frequency pair. Each line contains eight fields. Text fields must
use enclosing quote characters. Fields must be separated by a comma and
a space.
Example data:
; TXfreq, RXfreq, Licensee, Location, Latitude, Longitude, first emission mode, second emission mode
461.1625, 466.1625, "example licensee", "example location", 35.1028, -80.9420, "16K0F3E", ""
So what you posted from the change log I will read later and try that out. I definitely missed that. But what's meant for a FMP.ScanList.csv seems to work in the FMP24.ScanList file. My csv file is empty and it is definitely scanning the 20 P25 freqs I added to FMP24.scanlist.
