need some information about sdr
bonk83
Union,SC
what would i need to use sdr for a scanner in the 151 to 159mhz and trunking systems p25,dmr,nxdn and possibly pro voice i'm been searching for what i would need i didn't really understand it i will appreciate all the help
mandcaff
northern michigan
your best bet would be to get a couple rtl sdr .com usb sticks, unitrunker and dsd+.you would need some type of vac (virtual audio cable) there are differnt types some free some you have to pay for, thats all you would need.
bonk83
Union,SC
do i have to buy the unitrunker and dsd+ software are they different usb sticks for different frequencies and trunked systems
bonk83
Union,SC
this is probably going to be a stupid question since it is virtual are they actually a cable
bonk83
Union,SC
M105
No it is not a physical cable. It is a software audio device that shows up in your volume control/mixer like your speakers and microphone. It allows you to run an audio stream between programs. For example if you want your tuner program like Unitrunker to send its received audio to DSD+ you would set unitrunker to use the virtual cable as its output and set DSD+ to use the virtual cable as its input. It is like connecting a virtual wire between unitrunker and DSD+.
A typical application would be to connect unitrunker to DSD+ with a virtual cable and then listen to DSD+ output on your speakers.
I use VB Cable and donated a few bucks to the author. It is a handy little piece of work.
paulmohr
Adrian MI
I use VB cable for my screen capture and streaming software to patch in my Blue Yeti mic. Along with OBS and Reaper.
Still waiting for my SDR to get here from China lol. Tracking says it is in the US now so it shouldn't be long.
SteveSimpkin
Lancaster, CA
are they a specific sdr usb stick to get dmr and nxdn and vhf and uhf frequencies
No. All SDR USB stick receivers should cover the range of VHF/UHF frequencies typically used for business and public safety services. Most SDR-RTL receivers have a frequency range of 24 – 1766 MHz. Some models will also allow operation below 24 MHz.
What model did you buy?
paulmohr
Adrian MI
that is the one I have coming in the mail, I only ordered one though. I am not really looking to follow trunked system with it. I got mine more for looking for really strong signals that might be interfering with my regular scanner and doing some antenna testing. And just to play with in general.
M105
the (RTL2832U) can it receive weak signals from far towers
It is still a radio receiver and I find that the SDR dongles have decent sensitivity. Like any radio what it receives relies heavily on the antenna to which it is connected. If your scanner radio will receive the "weak signal from far towers" on your current antenna then most likely so will your software defined radio.
SteveSimpkin
Lancaster, CA
In general, these SDR-RTL sticks are very sensitive.
As to receiving signals from towers far away, that depends on a lot of other variables including how far away the tower is, your antenna characteristics, where your antenna is mounted (higher is usually between), interference from local RF sources, the terrain between your antenna and the tower, the type of coaxial cable used to connect your antenna to the SDR, etc.
bonk83
Union,SC
i have a centerfire vhf/uhf multiband antenna with 75 feet of rg11 the antenna is 20 feet high my elevation is 672 feet they are mountains to the northwest and the elevation goes down below
M105
Sounds good. The dongles were originally TV tuners and accept 75 ohm impedance nicely. You can use TV splitters. Again, if your scanner receives it your SDR probably will too.
