SDR# v1.0.0.1583 and scanner plugin ???
Saint
Fort Erie Ontario Canada
I installed SDR# v1.0.0.1583 and it's working, I went to the Russian web site and downloaded the scanner plugin and installed the .DLL into sdr# directory, I then copied and pasted the line into the sdrsharp.exe.config file.
When I put the scanner line into the sdrsharp.exe.config file I put the line in at the bottom of the file and save it but when I go back into the config file it's been moved to another line in the file. ????, this is the line I add.
<add key="Frequency Scanner" value="SDRSharp.FrequencyScanner.FrequencyScannerPlugin,SDRSharp.FrequencyScanner" />
this is the SDR.EXE.CONFIG FILE.
<?xml version="1.0" encoding="utf-8"?>
<configuration>
<configSections>
<section name="frontendPlugins" type="System.Configuration.NameValueSectionHandler,System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<section name="sharpPlugins" type="System.Configuration.NameValueSectionHandler,System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
</configSections>
<frontendPlugins configSource="FrontEnds.xml" />
<sharpPlugins configSource="Plugins.xml" />
<appSettings file="">
<clear />
<add key="processPriority" value="256" />
<add key="fftOffset" value="-40.0" />
<add key="pllPhaseAdjM" value="0.0" />
<add key="pllPhaseAdjB" value="-1.75" />
<add key="deemphasisTime" value="50" />
<add key="tuningLimit" value="0.45" />
<add key="spectrumAnalyzer.snrGradient" value="FFFFFF,1E90FF,000091,000050" />
<add key="spectrumAnalyzer.gradient" value="FFFFFF,ADD8E6,1E90FF,000050,000000" />
<add key="spectrumAnalyzer.envelopeColor" value="FFFFFF" />
<add key="spectrumAnalyzer.fillColor" value="1E90FF" />
<add key="waterfall.useUtcTimeStamp" value="False" />
<add key="waterfall.gradient" value="4A0000,750000,9F0000,C60000,FF0000,FE6D16,FFFF00,FFFFFF,1E90FF,000091,000050,000030,000020" />
<add key="useAntiAliasedDisplay" value="true" />
<add key="stepSizes" value="1 Hz,10 Hz,100 Hz,500 Hz,1 kHz,2.5 kHz,5 kHz,6.25 kHz,7.5 kHz,8.33 kHz,9 kHz,10 kHz,12.5 kHz,15 kHz,20 kHz,25 kHz,30 kHz,50 kHz,100 kHz,150 kHz,200 kHz,250 kHz,300 kHz,350 kHz,400 kHz,450 kHz,500 kHz,1 MHz" />
<add key="funcubeFrequencyCorrection" value="-21.0" />
<add key="softrockFrequencyMultiplier" value="4" />
<add key="RTLBufferLength" value="16384" />
<add key="minOutputSampleRate" value="32000" />
<add key="minThreadedSampleRate" value="1000000" />
<add key="airspy.vga" value="6" />
<add key="airspy.mixerAgc" value="False" />
<add key="airspy.mixer" value="6" />
<add key="airspy.lnaAgc" value="False" />
<add key="airspy.lna" value="1" />
<add key="airspy.sampleRate" value="0" />
<add key="airspy.decimation" value="0" />
<add key="airspy.trackingFilterEnabled" value="True" />
<add key="airspy.biasTeeEnabled" value="False" />
<add key="airspy.spyVerterEnabled" value="True" />
<add key="airspy.spyVerterPPM" value="0" />
<add key="airspy.usePacking" value="False" />
<add key="airspy.aliasFreeRatio" value="0.8" />
<add key="airspy.debug" value="0" />
<add key="airspyhf.debug" value="0" />
<add key="rdsUseFEC" value="True" />
<add key="timestampInterval" value="100" />
<add key="SDRIQReadBlockCount" value="1" />
<add key="zoomPosition" value="1" />
<add key="displayBeforeFilter" value="True" />
<add key="SDRIQOutFifoBlockCount" value="0" />
<add key="showBookmarks" value="False" />
<add key="rtl.tunerGain" value="14" />
<add key="rtl.sampleRate" value="3" />
<add key="rtl.tunerAgc" value="False" />
<add key="rtl.frequencyCorrection" value="69" />
<add key="rtl.chipAgc" value="False" />
<add key="rtl.samplingMode" value="0" />
<add key="rtl.offsetTuning" value="False" />
<add key="airspyhf.decimation" value="0" />
<add key="plugin.bandPlan.enabled" value="True" />
<add key="plugin.bandPlan.autoUpdateSettings" value="True" />
<add key="plugin.bandPlan.position" value="1" />
<add key="dnr.af.enabled" value="False" />
<add key="dnr.af.profile" value="0" />
<add key="dnr.af.threshold" value="-80" />
<add key="dnr.af.depth" value="15" />
<add key="dnr.af.smoothing" value="200" />
<add key="dnr.af.attack" value="20" />
<add key="dnr.af.decay" value="30" />
<add key="dnr.af.fft" value="5" />
<add key="dnr.af.quality" value="90" />
<add key="dnr.if.enabled" value="False" />
<add key="dnr.if.profile" value="0" />
<add key="dnr.if.boostSNR" value="False" />
<add key="dnr.if.threshold" value="-124" />
<add key="dnr.if.depth" value="15" />
<add key="dnr.if.smoothing" value="200" />
<add key="dnr.if.attack" value="20" />
<add key="dnr.if.decay" value="30" />
<add key="dnr.if.fft" value="5" />
<add key="dnr.if.quality" value="90" />
<add key="nb.bb.enabled" value="False" />
<add key="nb.bb.threshold" value="5" />
<add key="nb.bb.pulseWidth" value="50.0000007450581" />
<add key="nb.bb.lookupWindow" value="10.0000001490116" />
<add key="nb.demod.enabled" value="False" />
<add key="nb.demod.threshold" value="5" />
<add key="nb.demod.pulseWidth" value="50.0000007450581" />
<add key="nb.demod.lookupWindow" value="10.0000001490116" />
<add key="enableZoomFFTFilter" value="False" />
<add key="enableZoomIF" value="False" />
<add key="enableZoomMPX" value="False" />
<add key="enableZoomAF" value="False" />
<add key="spectrumAnalyzer.attack" value="0.2" />
<add key="spectrumAnalyzer.decay" value="0.14" />
<add key="waterfall.Attack" value="1" />
<add key="waterfall.decay" value="0.86" />
<add key="useTimeMarkers" value="False" />
<add key="fftSpeed" value="40" />
<add key="fftContrast" value="9" />
<add key="fftWindowType" value="3" />
<add key="spectrumStyle" value="3" />
<add key="fftView" value="2" />
<add key="fftResolution" value="6" />
<add key="detectorType" value="0" />
<add key="useAGC" value="False" />
<add key="agcThreshold" value="-50" />
<add key="agcDecay" value="500" />
<add key="agcSlope" value="0" />
<add key="agcHang" value="False" />
<add key="frequencyShift" value="0" />
<add key="frequencyShiftEnabled" value="False" />
<add key="swapIQ" value="False" />
<add key="correctIQ" value="False" />
<add key="markPeaks" value="False" />
<add key="fmStereo" value="True" />
<add key="filterAudio" value="True" />
<add key="unityGain" value="False" />
<add key="latency" value="100" />
<add key="sampleRate" value="48000 sample/sec" />
<add key="audioGain" value="52" />
<add key="AudioIsMuted" value="False" />
<add key="windowState" value="2" />
<add key="windowPosition" value="0,0" />
<add key="windowSize" value="1000,800" />
<add key="collapsiblePanelStates" value="0,1,0,0,0,0,0,0,0,0,0,0,0,0" />
<add key="splitterPosition" value="324" />
<add key="iqSource" value="4" />
<add key="waveFile" value="" />
<add key="centerFrequency" value="161612500" />
<add key="vfo" value="161375000" />
<add key="tuningStyle" value="0" />
<add key="fftDisplayOffset" value="0" />
<add key="fftDisplayRange" value="6" />
<add key="inputDevice" value="[MME] Microsoft Sound Mapper - Input" />
<add key="outputDevice" value="[MME] Microsoft Sound Mapper - Output" />
<add key="spectrumWidth" value="1920001" />
<add key="lockCarrier" value="False" />
<add key="useAntiFading" value="False" />
<add key="menuPosition" value="0" />
<add key="wfmState" value="216790,250,3,50,0,1000,1,18,0,1,0,0" />
<add key="nfmState" value="7910,1000,3,70,1,1000,1,12,0,0,0,0" />
<add key="amState" value="32000,1000,3,51,1,1000,1,6,0,1,0,0" />
<add key="lsbState" value="2400,1000,3,50,0,1000,1,1,0,1,0,0" />
<add key="usbState" value="2400,1000,3,50,0,1000,1,1,0,1,0,0" />
<add key="dsbState" value="6000,1000,3,50,0,1000,1,1,0,1,0,0" />
<add key="cwState" value="300,1000,3,50,0,1000,1,1,0,1,0,0" />
<add key="rawState" value="10000,1000,3,50,0,1000,1,4,1,0,0,0" />
<add key="topSplitter" value="200" />
<add key="bottomSplitter" value="200" />
<add key="leftSplitter" value="200" />
<add key="rightSplitter" value="200" />
<add key="menuIsHidden" value="False" />
</appSettings>
</configuration>
Steve
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
There is a space as mentioned. P lugin. If it got copied into plugins.xml like that that's why it failed. Also, make sure there are no extra characters in that file. I expect you also copied the .dll file into the root of your program folder.
Saint
Found the problem
:lol: Ok I found the problem you pointed out to me I missed it the first time it was the extra space in the line like you told me, the scanner is now installed into sdr#. I have to go back to the site and find the help file to see how to set the scan up. thanks so much for your patients and your help.
Steve
Saint
Need a little bit more help
I have the frequency scanner installed but can't figure out how to setup a scan between to frequencies, how would I put in a scan from 125.000 MHz to 130.000 mhz. I can open a box but not able to setup the scan. Here is the screen capture.
Steve
NYG
Does this scanner plugin work with only RTL-SDR radios, or does it work with all radios compatible for SDR#?
I don't normally use SDR# but since it works with the new PlutoSDR I'm checking it out. The scanner plugin looks like it's doing everything it's supposed to but it doesn't tune the radio.
