Old 10-07-2017, 3:05 PM
Default HDSDR - VFO B indicator?
New to HDSDR - just installed V2.76 and experimenting with it. Input is a Funcube pro connected to the IF output of my transceiver. CAT communications via Omni Rig and all is working well. What I'm looking for is a way to display an indicator (vertical line?) on the spectrum display so that I can quickly see where VFO-B is set relative to signals I see on the spectrum display. The indicator should move when VFO-B is tuned on the transceiver. Is there a way to do that?
