Old 10-10-2017, 1:18 AM
Default Number of input dsd plus
Hello I am using unitrunker 2 sdr and dsd plus decoding p25 phase 2.
But I also want to decode and listen to mototurbo If I buy another sdr dognal and antenna can I also input it to dsd and listen to turbo digital and unitrunker p25 using dsd with one computer
thanks clay
Old 10-10-2017, 10:39 PM
You're not listening to P25 Phase II with Unitrunker and DSD+.
Yes. In fact, you should buy two so you can follow trunked DMR/TRBO (and NXDN, etc.)
Old 10-11-2017, 1:49 AM
slicerwizard
I am using unitrunker and dsd plus with 2 sdr and listening to p25 phase 2
I am listening to
System Name:
Missouri Statewide Wireless Interoperable Network (MOSWIN)
Statewide, MO IL
County:
4 counties
System Type:
Project 25 Phase II
System Voice:
APCO-25 Common Air Interface Exclusive
Last Updated:
October 10, 2017, 6:22 pm ((4) Talkgroups Updated (Cape Girardeau County))
I followed this https://www.rtl-sdr.com/rtl-sdr-tuto...io-unitrunker/ and followed it and it is working
I have both p25 phase 2 and mototrubo in my patrol car and want to scan p25 and turbo on computer
Thanks Clay
Old 10-11-2017, 6:49 AM
Just because a system is capable of phase ii doesn't mean it's actually operating in phase ii. If just one user with an older radio associates with a given TGID/Site, that TGID falls back to phase i.
The only way you can know whether phase ii is in use is to see if the voice has a slot id (either 0 or 1). Phase i voice does not have a slot.
Old 10-12-2017, 1:31 AM
Sir, you don't appear to know what a system type of Phase II means.
I don't see a single talkgroup flagged as confirmed Phase II voice: https://www.radioreference.com/apps/db/?sid=6847
Bottom line: if you're hearing P25 voice with Unitrunker and DSD+, it's Phase I voice.
