Old 10-17-2017, 10:29 AM
dave3825's Avatar
Default Rtl Sdr dongle ir?
I saw this when I clicked tuner info within Sdrtrunk. I would like to know if there is a way to turn off the ir function since the dongle is not being used with a remote. Just curious.
DMR436HP Br330T Pro 93 Pro 95
Arc330Pro ProScan Freescan BCDX36HP Easy Manual Id Tracker
Old 10-18-2017, 4:23 AM
When I ported the original RTL driver to Java, I didn't add any code to interact with the IR sensor if/when present on the tuner.
Old 10-19-2017, 3:21 PM
simmsrep's Avatar
There is a linux program that is incorporated in the osmocom rtl-sdr project, rtl_eeprom.1, that will allow you to do this. It also has other functions for the RTL2832 dongles. You can read about it here Ubuntu Manpage: rtl-eeprom - EEPROM programming tool for RTL2832 based DVB-T receivers.
