MidNitRcr
- Joined
- Dec 8, 2004
- Messages
- 21
Hey everyone, need some help here...
I am attempting to setup my Airspy as a panadapter for my AOR 8600 and running into troubles. Here is my current setup:
AOR 8600 MK2 (in WFM mode) -> Airspy on 10.7mhz IF output -> GQRX on Mac OSX
The issue I'm running into is that I can't quite seem to get the settings correct in Gqrx for the airspy. When I tune to an FM channel on the radio itself I can see the waterfall display of the signal in GQRX, but it's for another station. I tried adjusting a half-a-dozen different "mhz" settings in the interface and eventually got one close, but the audio quality in GQRX was terrible. When I switched to another station on the Aor (NOAA WX, which uses NFM) almost everything disappeared from the display as if I wasn't even in the ballpark anymore with my GQRX settings.
Has anyone tried a similar setup and can shed some light? Or explain the 10.7mhz IF output on the Aor and how its supposed to work?
