RnR
- Joined
- Aug 30, 2010
- Messages
- 8
Hi troops...
I am an AirSpy user, successfully employing one on a laptop (Win7 based). However getting another one running on a desktop is giving me fits. When I'm lucky enough not to get a Bad Resource Pool Header BSOD, I ill still get a message that SDRTrunk (or the TunerManager) can't claim the USB device. Any ideas how I can rectify this error condition?
My log is shown below:
D:\Support - SDR\sdrtrunk_0.3.0-beta14>java -XX:+UseG1GC -cp "SDRTrunk.jar;*;lib
s/*;config/*;images/*" gui.SDRTrunk
13:36:03.103 INFO gui.SDRTrunk -
13:36:03.119 INFO gui.SDRTrunk - **********************************************
13:36:03.119 INFO gui.SDRTrunk - **** sdrtrunk: a trunked radio and digital dec
oding application ***
13:36:03.119 INFO gui.SDRTrunk - **** website: https://github.com/dsheirer/sdr
trunk ***
13:36:03.119 INFO gui.SDRTrunk - Host CPU Cores: 4
13:36:03.119 INFO gui.SDRTrunk - Host Memory Total: 16777216
13:36:03.119 INFO gui.SDRTrunk - Host Memory Max: 268435456
13:36:03.119 INFO gui.SDRTrunk - Host Memory Free: 9397248
13:36:03.119 INFO util.ThreadPool - Application thread pool created with [4] th
reads
13:36:03.119 INFO gui.SDRTrunk - Home path: C:\Users\htpc\SDRTrunk
13:36:03.135 INFO p.SystemProperties - SystemProperties - loaded [C:\Users\htpc
\SDRTrunk\SDRTrunk.properties]
13:36:03.135 INFO p.SystemProperties - SystemProperties - application propertie
s loaded [C:\Users\htpc\SDRTrunk\SDRTrunk.properties]
13:36:03.135 INFO settings.SettingsManager - SettingsManager - loading settings
file [C:\Users\htpc\SDRTrunk\settings\settings.xml]
13:36:03.369 INFO source.mixer.MixerManager - loading system mixer devices
[LOADED] Output: Primary Sound Driver CHANNELS: [MONO, STEREO]
[LOADED] Output: Realtek Digital Output(Optical) (Realtek High Defin
ition Audio) CHANNELS: [MONO, STEREO]
[LOADED] Output: Realtek HDMI Output (ATI HDMI Audio) CHANNELS: [MON
O, STEREO]
[LOADED] Output: Realtek Digital Output (Realtek High Definition Aud
13:36:03.369 INFO s.r.RecordingSourceManager - RecordingSourceManager - discove
red [0] recording configurations
13:36:08.595 INFO source.tuner.TunerManager - LibUSB API Version: 16777474
13:36:08.595 INFO source.tuner.TunerManager - LibUSB Version: 1.0.18.10866
13:36:08.626 INFO source.tuner.TunerManager - discovered [10] attached USB devi
ces
13:36:08.626 INFO source.tuner.TunerManager - usb device [1002:4397] NOT LOADED
: Unknown Device
: Unknown Device
: Unknown Device
13:36:08.626 INFO source.tuner.TunerManager - usb device [1002:4399] NOT LOADED
: Unknown Device
13:36:08.626 INFO source.tuner.TunerManager - usb device [1002:4396] NOT LOADED
: Unknown Device
13:36:08.641 INFO source.tuner.TunerManager - usb device [1002:4396] NOT LOADED
: Unknown Device
: Unknown Device
13:36:08.641 INFO source.tuner.TunerManager - usb device [046D:C52B] NOT LOADED
: Unknown Device
: Unknown Device
13:36:08.813 ERROR source.tuner.TunerManager - couldn't construct Airspy control
ler/tuner
source.SourceException: Airspy Tuner Controller - error while setting USB config
uration, claiming USB interface or reset the kernel mode driver
at source.tuner.airspy.AirspyTunerController.init(Unknown Source) ~[sdrt
runk.jar:na]
at source.tuner.TunerManager.initAirspyTuner(Unknown Source) [sdrtrunk.j
ar:na]
at source.tuner.TunerManager.initTuner(Unknown Source) [sdrtrunk.jar:na]
at source.tuner.TunerManager.initTuners(Unknown Source) [sdrtrunk.jar:na
at source.tuner.TunerManager.<init>(Unknown Source) [sdrtrunk.jar:na]
at source.SourceManager.<init>(Unknown Source) [sdrtrunk.jar:na]
at gui.SDRTrunk.<init>(Unknown Source) [sdrtrunk.jar:na]
at gui.SDRTrunk.main(Unknown Source) [sdrtrunk.jar:na]
Caused by: source.SourceException: couldn't set USB configuration 1 [LIBUSB_ERRO
R_NOT_FOUND]
at source.tuner.airspy.AirspyTunerController.claimInterface(Unknown Sour
ce) ~[sdrtrunk.jar:na]
... 8 common frames omitted
13:36:08.813 INFO source.tuner.TunerManager - usb device [1D50:60A1] NOT LOADED
: error constructing Airspy tuner controller
13:36:09.499 INFO icon.IconManager - loading icons file [C:\Users\htpc\SDRTrunk
\settings\icons.xml]
13:36:09.718 INFO playlist.PlaylistManager - Attempting to load version 2 playl
ist file [C:\Users\htpc\SDRTrunk\playlist\playlist_v2.xml]
13:36:09.874 INFO gui.SDRTrunk - starting main application gui
trunk ***
reads
O, STEREO]
ces
: Unknown Device
: Unknown Device
: Unknown Device
: Unknown Device
: Unknown Device
: Unknown Device
: Unknown Device
: Unknown Device
: Unknown Device
ler/tuner
runk.jar:na]
ar:na]
R_NOT_FOUND]
