I recently purchased an Airspy HF+ from Moonraker in the UK. I also own an Airspy R1 which I had always been happy with. I found a strange problem recently with the HF+ when I found what were clearly Tetra images from UHF appearing strongly in the Air Band. I cannot see similar images with the Airspy R1 or an old RTL dongle that I have. I was puzzled by this because I could see that Tetra signals in my area are not particularly strong, so I couldn’t understand why they appeared so strongly at around 130 MHz. See attached image.
I tried to post on the airpsy.group.io to see whether anyone else had seen similar UHF images, but I got a response from the Airspy owner Youssef Touil that the problem would be solved if I added extra filtering. I was sure that this couldn’t be an overload issue, so I applied two signals to the HF+ from two RF signal generators via a power combiner with both signals at -70 dBm. One signal was at 130 MHz and the other was at just over 390 MHz. The 390 MHz signal was clearly present close to the real signal at 130 MHz and the test showed that the spurious image was only 25 dB lower than the 390 MHz signal.
I replied to Mr Touil that when I purchased the product, Airspy had made a big deal about the fact that no additional external filtering would be needed with the HF+, a claim that they have now removed from their website. Given the suppression of UHF Tetra signals in the Air Band is only 25 dB, it is clear that in fact a LOT of extra filtering is required to make this band usable. I asked Mr Touil why he would not allow my post to go on the group – I wanted to understand whether others had seen the same issue or whether I had a bad device and he replied that my post was really a customer support question and they do not allow customer support questions to be posted on the group. I felt that he was very clearly censoring my post as it contained information about the product that he did not like andf did not want widely disseminated.
I am more disappointed about the attitude and lack of transparency than the problem itself, but it is clear that without substantial amounts of UHF filtering, the HF+ is useless for scanning the Air Band
Bobby
Bobby
