Old 02-02-2018, 4:46 PM
se's Avatar
se se is offline
Default RSP2 Pro?
Hello All.
Does this cable have Ferrites on it?
Thanks Sheldon.
Old 02-02-2018, 5:05 PM
se's Avatar
se se is offline
Hi.
I hope the pic got uploaded.
Sheldon.
Old 02-02-2018, 5:22 PM
Originally Posted by se View Post
Hello All.
Thanks Sheldon.
You are only showing the very ends of the cable in the picture, but from what is visible, there are NO ferrites on the cable.
Old 02-02-2018, 5:30 PM
iMONITOR's Avatar
No it does not.
Old 02-02-2018, 5:47 PM
Hello All.
Thanks Sheldon.
If it did, it would have big tubular lumps attached near the plugs at each end.
Old 02-02-2018, 5:55 PM
se's Avatar
se se is offline
Ok. I didnt think so neither. But wasnt sure.
Thanks Sheldon.
Old 02-02-2018, 6:18 PM
se's Avatar
se se is offline
Default Back again.
Hi.
Is this an appropriate cable? It looks like it will connect to the RSP2 Pro.
https://www.walmart.ca/en/ip/Tripp-L...okes-M-M-6-ft/
TPRD3OMR4K0YPNUB
Thanks Sheldon.
Old 02-02-2018, 6:28 PM
se's Avatar
se se is offline
I think this is the link I was trying to post, sorry.
https://www.walmart.ca/en/ip/Hi-Spee...RD6O5XNUCEXN7O
Sheldon.
Old 02-02-2018, 7:40 PM
c_snyder's Avatar
That's a usb mini-b, the RSP-2 (well all rsp's) takes a usb type-b connector. The cable you're looking for is like the one in your original picture, usb type-a to type-b.
If you can't find one with ferrite cores you can usually purchase the cores separate and wind them onto the cable yourself. I purchased several 1/2 inch snap on cores so I could wind the cable through several times.
Old 02-02-2018, 9:20 PM
prcguy's Avatar
Most small cores seen on USB and similar cables are 43 mix material and one pass of a wire through one core will have a very slight reduction of noise in the VHF/UHF spectrum and virtually nothing on HF.
I would use a longer than needed USB cable with no factory ferrite, then wrap 2 or 3 turns around a 43 mix snap on ferrite right at each USB connector. Then wrap 5 to 6 turns around a 31 mix large ferrite snap on bead right after the 43 mix one so you have two different mix cores in series at each end.
This will give you some reasonable choking impedance across most of the HF bands through UHF. In the frequency range where the different ferrites absorption overlap you will get increased choking impedance in that range.
prcguy
Old 02-03-2018, 9:38 AM
se's Avatar
se se is offline
Ok. Thanks for the replies guys.
Sheldon.
Old 02-03-2018, 10:19 AM
Flatliner's Avatar
What does this have thread have to do with RSP2 Pro??
Radios, antennas and bamboo in a pot that only needs watering every ̶s̶i̶x̶ twelve months.
https://www.youtube.com/watch?v=gmFPQJRkb5s
Old 02-03-2018, 10:31 AM
prcguy's Avatar
SDRPlay recommends a USB cable with ferrite for the RSP2 series and my comments were about how to do that. Why would that not be in line with the thread?
prcguy
Old 02-03-2018, 10:36 AM
Flatliner's Avatar
You're right. By the seventh post, the RSP finally got a mention.
Old 02-03-2018, 2:57 PM
se's Avatar
se se is offline
Hi All.
Is there anything in this search results from Walmart That is appropriate?
htps://www.walmart.ca/search/usb%202.0%20type-a%20to%20type-b.%20
Or from www.startech.com?
Sheldon.
Old 02-03-2018, 7:26 PM
c_snyder's Avatar
I don't see anything in those results. Like prc said the ferrites that are put on consumer cables are just meant to filter a small bit of RFI to an acceptable level. For radio monitoring you'll need a higher level of filtering with the correct ferrite material. A mix of 31 and 43 would be best. You can find these on amazon or ebay. I would get either a snap on or toroid of each mix for each end and like he said loop your cable though several times.
The more you can loop the cable through the ferrite the higher the impedance. (lower noise). That's why consumer cables with small single pass ferrites are not really ideal.
These are two nice ones here if you're interested.
43 Mix
31 Mix
Old 02-04-2018, 5:36 AM
Flatliner's Avatar
An off-the-shelf cable that works well enough, is in the link below. Postage could be a bit high to your location though.
https://www.ebay.co.uk/itm/Heavily-s...gAAOSwA3dYVr-p
Making up a lead with a ferrite mix, as c_snyder has posted, would do the best job.
It's worth noting though that the SDRplay kit doesn't suffer badly even with a plain cable, though improvements can often be made.
Old 02-04-2018, 9:19 AM
prcguy's Avatar
I've run my RSP2pro with and without ferrites on the cable and have not noticed any difference here yet, although I have very effective choke baluns at each end of my antennas.
My main operating position has lots of computer equipment and antenna cables run right next to computers, routers, switching power supplies, etc and was picking up noise and carrying it to the antenna. Placing chokes at the antenna and radio end made a noticeable decrease in my noise floor and removed a lot of birdies.
Every installation will be different, requiring different methods of reducing noise. Its a good precaution to install ferrites on the USB cable but I would rather identify any noise using a separate battery powered receiver, then address problems as they are found. Otherwise you can spend a lot of money on ferrite and filters that may not be necissary.
prcguy
Old 02-04-2018, 3:47 PM
devin_wight's Avatar
Hello All.
Thanks Sheldon.
I don't see any. The are noticeable as in the picture I attached.Name:  30-awg-high-speed-hdmi-cable-with-ferrite-cores-6-feet_NID0007251.jpg
Sent from my SM-G955U using Tapatalk
Old 02-04-2018, 5:50 PM
se's Avatar
se se is offline
Hi All.
Im gonna take the advice of some in this thread I started and buy some separate ferrites. What size in this link do I buy? Could you tell me by item number plesde?
https://www.walmart.ca/search/Ferrites
Thanks Sheldon.
