A couple of problems with SDR#
GrumpyGuard
NEWBERG
1. Windows 10 shuts down SDR# after 5-10 minutes of use. I get the following error message:
SDR Sharp has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
2. I have two dongles plugged into my computer and when I open RTLSDR Controller it shows one Generic RTL2832U OEM (0) device. The dropdown is greyed out, and won't allow me to change dongles or sampling mode.
c_snyder
It could be an issue with your computer or USB drivers. I have seven rtl receivers plugged in and SDR# does just fine. I can switch between them with no issues.
