Receive only or transmit? For receiving you can get a $15 (or less) USB dongle and use free software such as SDR Sharp. There are better dongles. www.rtl-sdr.com is a good place to start and the dongle they market is notably better for just a few extra dollars. Above that I'd recommend Air Spy, which is where you find that software. Above that you can easily get into several hundred dollars and into thousands.
The only consistent issue is Win10 replacing the correct drivers with the incorrect ones when updating the OS.
Do you think it would be easier to run using Ubuntu Linux instead of Windows 10?One way around that for Windows 10, Pro users can edit group policy or registry to exclude drivers from updates, home users will only have the registry edit available
In Group Policy Editor (gpedit.msc):
Computer Config > Administrative Templates > Windows Components > Windows Update
"Do not include drivers with Windows Updates" - set to enabled.
Or in the registry:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate
ExcludeWUDriversInQualityUpdate set to 1
If the setting isn't there which is likely in Home edition create a new DWORD
Sent from my VS986 using Tapatalk
It all depends what your coMmonly used applications are. For example my primary os has been ubuntu for about 5 years now. It works for everything I use on a daily basis, but when I absolutely have to use Windows, I run it in a virtual machine under ubuntu.It very well may be. But some may need to use Windows for one reason or another. Nowhere near all Windows software works with Linux. Sometimes stuff is supported well in Linux, better than Windows, some isn't. It's certainly worth looking in to. My favorite is Xubuntu. But I also use Windows 10.
