File this under missing feature not bug, and I post it so others have a reference.
Now that I actually have OP25 decoding phase2 (thanks boatbod) I noticed something today. With the scanner running in parallel with OP25 fire station alerting tones (Quick Call II) were not generated in OP25, but were in the scanner.
Tones with the IMBE/AMBE vocoders:
Tones such as quick call, DTMF are not coded in the same way voice is. The DVSI vocoders detect the tone and specially code it outside of the voice process. These types of tones are coded into the chip. If you have ever noticed that certain tones sound crystal clear this is why.
If you happen to be running OP25 and notice this behavior, its not a bug, its a missing feature, it should be reasonably straightforward to reverse engineer if anyone has the time and patience and I am sure Mike and boatbod would appreciate the help. The code may be in SDRTrunk as well. I seem to remember the IMBE vocoder implementation generating tones.
