The RadioReference.com Forums
-   Software Defined Radio (https://forums.radioreference.com/software-defined-radio/)
-   -   DSD Plus tags to RadioFeed (https://forums.radioreference.com/software-defined-radio/377805-dsd-plus-tags-radiofeed.html)
jonathany1 10-10-2018 1:31 PM
Has anyone come up with a way to get alpha tags directly from DSD to RadioFeed? I know if you integrate DSD and Unitrunker there are ways to get it done. But in my case the FMP tuner built in to DSD works better on the systems I monitor.
nated1992 10-12-2018 11:51 PM
Depending on the system your following just go to trunksdr it decodes plays audio and will send to audio server with tags all in one program... I like it quite well. Although it dosnt have as many systems available currently
jonathany1 10-13-2018 9:27 AM
I have tried to get this program to work a dozen times. This morning i set out to make it work and i finally got it decoding p25 on three systems using airspy mini. Now for setting up groups and streams.
alabamarailfan 10-13-2018 10:31 PM
Hey Nated, when I do a search for trunksdr, I don't have much luck but I did get results for a Java based app called SDRTrunk. Is this the one you meant? I would be interested in checking it out!
nated1992 10-13-2018 11:30 PM
Yes it is, sorry a get stuff backwards, I have it running like it a lit however I've ran into a issue trying to use two sdr reciver for two systems it will work for a bit then both signals will drop out. ������
