SDR# and the Vasili Scanner plug in
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
see the picture. any reason why half of the band sweep is red and the other half is blue?
this just started - never seen it do this before.... typically it's all blue.
doug
thewraith2008
Maybe by accident you highlighted half the spectrum and locked it out.
E.g.
If you left click mouse hold and drag over spectrum then click left button (the highlighted section).
To undo left click mouse hold and drag over affected spectrum then click right button (the highlighted section).
Of course this means what was set there before is now lost.
thewraith2008
Odd indeed. Worked here.
In any case you probably could have just deleted the "scanner_entryes.xml" file in the SDR# folder.
or
Edited out the "<SkipFrequencyArray>" entries in "scanner_entryes.xml" file with notepad.
E.g. remove the red text.
Code:
[color=red]    <long>438175000</long>
    <long>439375000</long>[/color]
  </SkipFrequencyArray>
