Bubbarx
Good Afternoon all,
After much work I appear to have gotten OP25 configured correctly so that it is monitoring my town's channels, however, I do not get audio from any of the talk groups it picks up. Looking at the log file I can't find any errors that stand out. The system sound is functioning correctly, tested it with another app. I have also made sure that it wasn't just encrypted channels that I wasn't receiving audio on. I am really at a loss at this point. I will upload a copy of the log shortly after it runs for a bit longer so there is more to go off of.
As an aside, for some reason, in order to actually receive the control channel, I have to use a frequency that isn't even listed as one of the primary channels in the database. 500.7954 vs the actual listed channels 500.4375, 500.5875, 500.8375
Computer is a MacBook Pro (2015)
OS is Ubuntu 18.04
When checking the sound settings the python pluggin shows up as an active sound application as: ALSA plug-in [python2.7]
As far as I can tell with the graphical plot, it appears to be tuned to the very peak as well.
Here is my current launch code
./rx.py --args 'rtl' -N 'LNA:47' -S 2400000 -f 500.7954 -o 25000 -q -2 -T trunk.tsv -v 1 -V -2 -U 2> stderr.2
Log:
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Using two-stage decimator for speed=2400000, decim=25/4 if1=96000 if2=24000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail: pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
op25_audio:pen_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1], do_nocrypt[0]
Reading blacklist file
audio device: default
1540162111.265666 control channel timeout
1540162306.927546 voice update: tg(4001), freq(500437500), slot(-), prio(3)
1540162308.894927 voice update: tg(4001), freq(500437500), slot(-), prio(3)
1540162310.860017 voice update: tg(4001), freq(500437500), slot(-), prio(3)
1540162661.229738 voice update: tg(18001), freq(500437500), slot(-), prio(3)
1540162663.466235 voice update: tg(18001), freq(500437500), slot(-), prio(3)
1540162665.376601 voice update: tg(18001), freq(500437500), slot(-), prio(3)
1540162667.455580 voice update: tg(18001), freq(500437500), slot(-), prio(3)
1540162669.418792 voice update: tg(18001), freq(500437500), slot(-), prio(3)
1540162671.438158 voice update: tg(18001), freq(500437500), slot(-), prio(3)
1540162674.444861 voice update: tg(18001), freq(500437500), slot(-), prio(3)
1540162686.894770 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162688.914908 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162691.043115 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162693.063457 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162695.248276 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162697.490644 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162720.751264 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162723.046362 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162725.067947 voice update: tg(4001), freq(502487500), slot(-), prio(3)
1540162727.303213 voice update: tg(4001), freq(502487500), slot(-), prio(3)
OS is Ubuntu 18.04
Log:
